97 t100 4x4 Front spindle nut
#803414
04/07/07 07:19 AM
I purchased a 54mm hub socket (OTC 6612 part number). How snug should you tork the nut on the front spindle and bearing?
Fix it myself 1997 T100 SR5 4X4 190,000 miles Ext.Cab 5 speed standard All original Except: Bilstein shocks,Steering stabilizer Aisin Hubs
Re: 97 t100 4x4 Front spindle nut
[Re: ErikB]
#803416
04/08/07 02:34 PM
Thank You ErikB. I bookmarked the link it is very helpful Bryan <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: 97T100SR54X4]
#803417
04/08/07 02:46 PM
you overtighten it, loosen it a little bit and then torque it down. that is for the inner one. then put that star washer in there and torque the outer one. then bend the tabs on the star washer. use the torque specs in the article.
Scott Landon 1995 T100 - total buildup underway 1988 4Runner (22RE, W56) - new DD 2005 Dodge CTD 4x4 - Tow Beast 1990 Spec Miata 2010 GT3 2013 E92 M3
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6007 MB (Peak: 0.6602 MB) Data Comp: Off Server Time: 2026-06-10 17:38:28 UTCValid HTML 5 and Valid CSS
