I guess I will have to do it
#803514
04/07/07 08:03 PM
I have a pin-hole leak in the top of my radiator near the upper hose. I put the steel wool to it and, now have it down to bare metal...and a tiny hole with hairline crack is visible.
So my choices are:
A..plumbers solder- low melting point, but not a strong material. Doesnt build up a cap very well either
B..braizing rod- high melting point might cause damage to radiator, but will easily cap off a hole this small
C..the newer stuff like staybrite 8 - supposed to be good stuff (when used for copper tubes to brass) fairly low temp but durable
I wonder hot I can get this metal ? What do repair shops use? Does anyone have a clue about these radiators? It's marked Denso- I guess it is the original one
1989 5 door montero 3.0 auto stock original Japanese about 200k miles
Re: I guess I will have to do it
[Re: generation_one]
#803515
04/07/07 11:04 PM
Is the hole in the core or on the top? I had a little leak on top near the cap and used some high temp epoxy and haven't had any issues whatsoever. And the epoxy was only a couple of bucks!
'87 Raider - 2.6L Rebuilt by me, BSE installed. Superwinch manual hubs. LSD, Squirters and bouncy seat added. Cobra CB w/ PA (PA coming soon). 31x10.5x15 Futura Dakota rubbers; Pro Comp Add-A-Leaf w/ Rancho RS500's in the rear, KYB's up front.
[Re: SpideyRaider]
#803516
04/08/07 12:12 AM
Solder it up with a propane torch, or mapp gas, and some silver solder.
Easy fix.
[Re: LandRaider]
#803517
04/08/07 02:06 AM
Easy fix. Thats what I would do. <img src="/forums/images/graemlins/kewl.gif" alt="" />
96 Montero LS 24V DOHC 3.0L. 98 Montero 24v SOHC 3.5L, factory rear locker, Winter/tow package. 63 Jaguar XKE 3.8L FHC 2000 Mercedes-Benz e430 07 fj cruiser
[Re: cmonty72]
#803518
04/09/07 02:10 AM
Radiators are put together with solder, and note that the upper tank is soldered to the core. I would still solder it, with silver solder, but I'd keep a wet rag between the solder site and the core-tank joint. Radiator shops use a very wide cool gas flame under quite low pressure for their soldering work, but I guess you'll need more heat for silver than lead....
