smog #803607 04/08/07 08:50 AM
rollin Offline OP
I have a 1989 4 runner that won't pass smog. Ive replaced the mass air flow sensor , the TPS ,cap & rotor,spark plugs PVC valve and a BOSCH universal O2 sensor. I have also run injector cleaner thru the gas tank & checked the EGR system and it is working. The smog check was - @ 2500 rpm the limit for the HC ppm 220 and the truck read 90 (pass) the CO% limit is 1.20 the truck read 1.16 (pass). The idle test @ 796 rpm is HC ppm limit is 220 the truck read 253 (fail) and the CO% limit 1.20 and the truck read 4.44 ! (fail)!!! . What could cause this ? should I bump the idle speed up to 1000rpm ? Would retarding the timing 2 deg help ? Any help is welcome . <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: smog [Re: rollin] #803608 04/08/07 11:20 PM
DRTDEVL Offline
Ditch the Bosch sensor... Get a Denso.
The Bosch sensor does not protrude enough into the exhaust stream to get an accurate reading, and will allow your engine to run rich.
Other than that, the Cat could need replacement. I am still leaning towards the Bosch sensor.
Re: smog [Re: rollin] #803609 04/09/07 06:22 AM
SoCalRunner Offline
I had a faulty coolant temp sensor that caused bad readings at smog check.
Re: smog [Re: SoCalRunner] #803610 04/10/07 04:41 AM
rollin Offline OP
Thank you , was there only one temp sensor ?
Re: smog [Re: DRTDEVL] #803611 04/10/07 04:42 AM
rollin Offline OP
Thank you, I will try that.
Re: smog [Re: rollin] #803612 04/10/07 05:03 AM
kewlynx Offline
www.sparkplugs.com offers Densos.
**ubi apis- ibi salus**
Re: smog [Re: kewlynx] #803613 04/11/07 01:06 AM
rollin Offline OP
Thank You all
Re: smog [Re: rollin] #803614 04/16/07 04:02 AM
rollin Offline OP
whooohooo it passed the 02 sensor worked!!! Thank You all so much ! <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6198 MB (Peak: 0.6969 MB) Data Comp: Off Server Time: 2026-06-19 05:29:48 UTC
