Here are the pics:
![[Linked Image]](http://img440.imageshack.us/img440/6243/1000164ro8.jpg)
As it sits now 31x10.5's with 2" body lift
![[Linked Image]](http://img440.imageshack.us/img440/5071/1000171aa0.jpg)
What I cut away to make the radiator fit and to lower it some
![[Linked Image]](http://img440.imageshack.us/img440/640/1000170ca3.jpg)
Motor mount passanger side
![[Linked Image]](http://img440.imageshack.us/img440/8754/1000169ke2.jpg)
Motor mount driver's side
![[Linked Image]](http://img440.imageshack.us/img440/6184/1000172mp7.jpg)
A little trimming under the hood to stop the radiator from hitting it
![[Linked Image]](http://img440.imageshack.us/img440/5776/1000173ql1.jpg)
B&M shifter used in place of the original. This is the only mod done to the interior
![[Linked Image]](http://img440.imageshack.us/img440/3793/1000174hv7.jpg)
Motor to trans showing clearance around the trans tunnel
![[Linked Image]](http://img440.imageshack.us/img440/7012/1000175aw4.jpg)
No modifications needed to the firewall. Just remove all the un needed original equipment
![[Linked Image]](http://img440.imageshack.us/img440/5071/1000177px4.jpg)
Mount for rear of trans. Original cross member used. Piece of 2x2 tubing used as spacer
![[Linked Image]](http://img440.imageshack.us/img440/8694/1000178in8.jpg)
Another pic of back trans mount
[img]
http://img440.imageshack.us/img440/6140/1000179hu0.jpg[/img]
Rear of transfer case and rear drive shaft
[img]
http://img440.imageshack.us/img440/4416/1000180gw9.jpg[/img]
Driver's side showing shifter linkage and driver's side exhaust
[img]
http://img440.imageshack.us/img440/1511/1000181kv1.jpg[/img]
Where front drive shaft would mount to transfer case looking forward to front diff
[img]
http://img440.imageshack.us/img440/7534/1000182qd3.jpg[/img]
Front of oil pan, front diff and sway bar
[img]
http://img440.imageshack.us/img440/7438/1000186bu2.jpg[/img]
Transmission to transfer case connection and trans monuting bracket
[img]
http://img440.imageshack.us/img440/7118/1000183by8.jpg[/img]
Rear of transfer case and drive shaft from passanger side
[img]
http://img440.imageshack.us/img440/1283/1000188wn3.jpg[/img]
Let them know what's under the hood
[img]
http://img440.imageshack.us/img440/7915/1000189uz8.jpg[/img]
Driver's side and front.
Carb is currently off as well as most of the front of motor. I intend to pull the drive train this summer and go through it (it's been sitting for 10 years now). I've got an aluminum intake and a holley 4 barrel ready to go on it. Got a good cam and lifters picked out too that should give it a little more umph! Looking back alot of the cutting I did up front wouldn't of been necessary if I had just had a custom radiator made to fit. Oh well the mistakes you make when you are young. As you can see in the pictures I just went with an old coil and points setup for the distributor. This made hooking into the stock wiring a breeze. No computers of hei to deal with. Also alot easier to diagnosis engine problems. I will probably switch out the point distributor for a mallory unilite setup.
When I first did the swap I originally put a Ford 3.8 in. Switched it out for a 302 because I didn't think it had enough power. When I switched to the 302 I didn't have to move the motor mounts or anything. Just unblotted the 3.8 from the motor mounts and tranny and dropped the 5.0 in. The exhaust and motor mounts lined right up. If you wanted to do this mod and not use a V8 then you could go the 3.8 route and even use some of the high output turbo'd engined that were put in T birds and Cougars.
Hope this give some insite into how doable this drive train swap really is.
