Needs Work #803885 04/09/07 06:42 AM
thefarky Offline OP
My old junker: 1949 Jeep Willys CJ3A
has a lot of carbon built up under the head. What do you think is the best way to remove it all besides scraping it?
Also, would it be worth it to remove the engine and rebuild it that way?
Note: I don't think she's ever been overhauled.
1995 Toyota Pickup, SR5 3.0V6, 31X10.50 Mud Tracs
Re: Needs Work [Re: thefarky] #803886 04/10/07 01:17 AM
BigJim Offline
If it ain't broke don't FIX it!!
Them old things had bout maybe 7 to 1 compression anyway! Leaving it alone will prolly improve it. The things will burn the lowest octane ever found anywhere.
Re: Needs Work [Re: BigJim] #803887 04/10/07 04:28 AM
9
93yj Offline
C'mon Jim..."THEM old things"? You sound like you're from Texas!!! Heh, JK Jim. I know you're a good sport!!!
Re: Needs Work [Re: 93yj] #803888 04/10/07 05:46 AM
BigJim Offline
93 the engine in them was at least 10 years older than they are. I'm not gonna look it up but I betcha it is at least 70 years old by now.
Re: Needs Work [Re: BigJim] #803889 04/10/07 06:08 AM
thefarky Offline OP
The engine is actually from a '42 Jeep. I need to find out why it's burning a lot of oil(blue smoke out of the exhaust). I'm hoping it's just the rings or head gasket and not a cracked block or head. I'm going to replace the gasket, rings, and get the head checked for cracks. Hopefully that will solve it! Any ideas?
Re: Needs Work [Re: thefarky] #803890 04/10/07 04:01 PM
BigJim Offline
First guess is the valves are not sealed properly. That is the ONLY place I'd be taking things apart.
You gotta remember them old engines smoked from the factory! If the thing runs ok I'd be leaving it ALONE! If the plugs don't fowl and it gets up the trail be thankful and stay out from under the hood.
Re: Needs Work [Re: thefarky] #803891 04/10/07 04:27 PM
Bigbird79 Offline
If you are actually going to take the engine apart, I would be looking at the block for cracks, not so much the head. A buddy of mine is doing a CJ2 or 3 with the little Godevil 4 cyl flat head in it, and he had cracks in the block from the waterjacket to the outside, and between areas of the waterjacket, nothing to the cylinders or valves though.
PHP: 7.4.33 Page Time: 1.772s Queries: 15 (0.004s) Memory: 0.6122 MB (Peak: 0.6903 MB) Data Comp: Off Server Time: 2026-06-20 07:35:47 UTC
