Can I lube a double-cardon joint? #804059 04/10/07 12:57 AM
BLSMafia Offline OP
I have a '79 J-10 and there's a squeak from the double-cardon joint at the rear of the front drive shaft. Can I lube this or do I have to replace it? Thanks for the info.
Re: Can I lube a double-cardon joint? [Re: BLSMafia] #804060 04/10/07 03:15 AM
BobRowe Offline
Look to see if it has grease fittings on it. Most of the ones I've had have the fittings.
Re: Can I lube a double-cardon joint? [Re: BobRowe] #804061 04/11/07 02:45 PM
superdawg Offline
Once the noise starts, grease is only prolonging the need for a new shaft (or at least a rebuild).
SD
Re: Can I lube a double-cardon joint? [Re: superdawg] #804062 04/12/07 12:21 AM
BLSMafia Offline OP
New shaft? Or new joint? I replaced the front driveshaft 6 months ago. thanks
Re: Can I lube a double-cardon joint? [Re: BLSMafia] #804063 04/12/07 02:47 PM
superdawg Offline
With CV shafts, you must realize that only a driveshaft expert can properly determine if the ball stud is worn enough to need replacing, or if the slip is marginal...
I let my driveline guy make those calls, I trust what he says. But I never look for a "this repair will get you by for a while" type responsefrom him. I want a "when I rebuild/build this shaft it will last and work like new" response.
All I'm saying is, once noises start, the damage is done.
Lubing all of the 5 zerk fittings on a common cv shaft will only prolong getting is rebuilt or replaced.
SD
Re: Can I lube a double-cardon joint? [Re: superdawg] #804064 04/12/07 05:17 PM
BLSMafia Offline OP
might be replacement time then because I cannot find one single grease fitting on this joint. Might be ungreasable?
Re: Can I lube a double-cardon joint? [Re: BLSMafia] #804065 04/15/07 06:59 PM
s10er8 Offline
You might have to install your own fittings and/or take the driveshaft out to grease it.
Re: Can I lube a double-cardon joint? [Re: BLSMafia] #804066 04/16/07 09:29 AM
80CJ Offline
I have a 2001 Chevy S-10 2WD extended cab with 4.3 V-6. It has 2 piece drive shaft with a double cardan joint on each end of the rear drive shaft. Each double cardan joint has a flush grease fitting for the centering ball. I had to really look closely to find these fittings. I've found that it is easier to just remove the drive shaft to access these grease fittings. It seems I can never get the grease gun at the correct angle if I try to grease the joints with the drive shaft in place.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6162 MB (Peak: 0.6971 MB) Data Comp: Off Server Time: 2026-10-26 07:16:50 UTC
