HEY ADRIAN, YES THE FRT HALF OF THE CASES ARE THE SAME AS LONG AS BOTH OF THEM ARE THE MUA, THE DSL SWAP I DID LAST WAS JUST THAT, A DSL MUA FRT HALF , TRANS PLANTED ONTO AN 89 MUA 4WD GAS ENG 5SPD ,, I ALL SO CONVERTED IT TO WORK WITH CABLE INSTEAD OF THE HYDRAULIC SETUP , SO YES YOU CAN USE A 2WD TRANS , BUT A DIVORCED T/C MAY BE A BIT LONG, HOW EVER THE T/C FROM ANY AUTOMATIC TRANS ISUZU 92 AND UP WILL SLIDE RIGHT ON THE OUTPUT SHAFT OF THE 2WD , SAME SPLINE COUNT AS THE AUTOMATIC OUTPUT TO THE INPUT OF THE T/C , YOU WOULD HAVE TO WORK OUT THE REAR SEAL AND BUSHING ON THE 2WD , BUT IT IS FEASABLE JERRY
