Page 4 of 4 1 2 3 4
Re: Indy 4X rumor [Re: Smiley] #804429 04/16/07 07:44 PM
matthew Offline
i disagree w/ that
i suppose it could actually be like the 96-97 rear axle which is slightly wider. w/ a matching widthe 96-97 front IFS.....would make sense.
so basically it is the same as a 1996-7 RS (if there was such a thing in the US) w/ a 98+ drivetrain.
[splitting hairs]
'93 RS 3.2L - DD/trail build
'97 7.3L Powerstroke - tow rig
'71 FJ40 - V-8, nv4500, atlas, D60, 14B - current build
Owner: http://www.INDEPENDENT4x.com
m-f 9am-6pm EST. 804-550-0480
Re: Indy 4X rumor [Re: matthew] #804430 04/17/07 04:05 PM
Smiley Offline
No hairs here - just tryin' to lay out the facts for future reference...
You have 3 different widths of HD Tie Rod Centers... My VX took the longest ones you've got.
Additionally, I just installed a set of brand new OEM Upper & Lower Ball Joints... The same exact ones that go on the 1998+ Trooper (the Lowers being the 'long' variety -- the extra width up top is built into the actual UCA itself, so it uses the same Upper Ball Joint either way).
*** The thing is, I *believe* the Trooper front suspension remained the same from about 1995-on, once they started using the fender flares & 'wide-track' front suspension.
What I do know, as far as ordering part numbers...
The VehiCROSS' front suspension is the 1998+ Trooper's... 100%.
The REAR is the older, non-modified 12-bolt from the earlier 1996-97 Trooper.
They used a whole lot of off-the-shelf parts, mixed-and-matched...
Heck, the dashboard is from the 1996-97 RODEO <img src="/forums/images/graemlins/wink.gif" alt="" />
<img src="/forums/images/graemlins/smile.gif" alt="" />
Six Isuzus, so far... still have three of them.
Page 4 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.5974 MB (Peak: 0.6466 MB) Data Comp: Off Server Time: 2026-10-21 22:03:28 UTC
