87 Cherokee Tranny #804578 04/12/07 03:35 AM
mmcpeck Offline OP
I've heard that some of the transmissions in older Jeeps only pump fluid in neutral and not in park. Is that true for my 87 Cherokee with the 4.0L, not sure which tranny is in it.
Thanks.
Re: 87 Cherokee Tranny [Re: mmcpeck] #804579 04/14/07 02:37 AM
mmcpeck Offline OP
Wow, did I stump you guys? Nobody has ever heard of some Jeep transmissions only pumping in Neutral and not in Park?
Big Jim?
Re: 87 Cherokee Tranny [Re: mmcpeck] #804580 04/14/07 03:25 AM
BigJim Offline
Nope! Stumped...
Re: 87 Cherokee Tranny [Re: mmcpeck] #804581 04/14/07 06:01 AM
BobRowe Offline
The only Jeep auto tranny I'm familiar with if the TF 999 in my CJ7. It pumps in all gears and N & P.
Re: 87 Cherokee Tranny [Re: mmcpeck] #804582 04/21/07 04:51 AM
MrCrowley Offline
i dont know exactly but a friend of mine told me that they only pump in neutral. he had an older jeep he used to push snow with and he blw abu 4 or 5 trannys till he had a mechanic friend of his tell him to let it warm up in neutral and he started doing that and never had a problem after that so try it that wy it may help you
Re: 87 Cherokee Tranny [Re: MrCrowley] #804583 04/24/07 06:23 AM
doublediamonds Offline
well if its true thats good to know i got my 78 cherokee but no ive never heard of it either
If you cant get there in a jeep you probably dont need to get there
Re: 87 Cherokee Tranny [Re: doublediamonds] #804584 04/25/07 12:01 AM
playinmud Offline
i know your supose to put the transmission in neutral after doing a filter and fluid change
WHEN THE ROAD ENDS, THE FUN BEGINS
97 sahara, 4in skyjacker lift, 33in tires, borla header & catback, 10in subs
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6083 MB (Peak: 0.6850 MB) Data Comp: Off Server Time: 2026-06-10 09:39:02 UTC
