38mm weber carb again? #804610 04/12/07 05:14 AM
L
Lil_Jon Offline OP
Anyone ever run into any issues with there 38mm weber?
Just looking for some info before I install this bad mofo this weekend.
Re: 38mm weber carb again? [Re: Lil_Jon] #804611 04/12/07 05:45 AM
Scerb Offline
http://www.redlineweber.com/
Click on the 'tech information' link on the left. Should have all the info you will need. <img src="/forums/images/graemlins/kewl.gif" alt="" />
-Scerb
Re: 38mm weber carb again? [Re: Scerb] #804612 04/12/07 02:09 PM
subliminaltrips Offline
the only thing i didnt like about a carb is the fact it doesnt like upward slopes but ive since been able to tune it a bit better using a 1-4 psi regulator from summit and i dropped my float level down about 5mm from the factory preset level. i run the truck at about 1 psi in the woods and then adjust it to 2 psi on the street, i have a gauge which makes it easy.
heres my thread.
http://www.4x4wire.com/forums/showf...mp;amp;sb=5&o=14&fpart=1
Re: 38mm weber carb again? [Re: Lil_Jon] #804613 04/12/07 02:57 PM
dcg9381 Offline
What other mods are on your motor? I've used the 32/36 and 38mm - couldn't feel a difference on a mildly mod'd motor between the two, unless I went to the gas pump!
22REturbo.net
1988 4Runner
Re: 38mm weber carb again? [Re: dcg9381] #804614 04/12/07 03:15 PM
ive got a complete engnbldr street rv,os ss valves with his 261c cam ,quench set at .007" thorley header 2/1/2 inch pipes. 5.29s locked on 35x15.5 tsl sx's
its real torquey , my next mod will be the msd ignition.and an lce adjustable cam gear. i get about 12mpg now,i think it runs a little rich on the mains still so im going to run a smaller main jet its a 170/170 factory, im going to try a 165 on both sides. i think the smaller jet will help with mileage. and help me get a little more power in the mid rpm range. now it kicks hard off idle to about 3000 rpm it makes its best power down low which is what i like but id like to help it pull a little higher like 4000 or so.
Re: 38mm weber carb again? [Re: subliminaltrips] #804615 04/13/07 06:29 AM
87Toy4x4 Offline
12 MPG!!! that sends chills up my spine. something isn't right. i cant imagine getting that kind of mileage out of my 22r. the weber can't suck that much gas can it? i get anywhere from 17-24 mpg depending on the type of driving i'm doing and which way the wind is blowing lol.
Re: 38mm weber carb again? [Re: 87Toy4x4] #804616 04/13/07 06:00 PM
Scerb Offline
Fawk man, you ever gotta downshift when the wind picks up?? IT SUCKS! <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: 38mm weber carb again? [Re: 87Toy4x4] #804617 04/13/07 07:33 PM
SALMONHEAD Offline
Over the past few years, my 22r with the Weber 38 has averaged; Off-road days (including to & from trailhead) 16mpg, Daily commute (35 miles round trip) 16.5 winter, 17.5 summer, Highway trips 18. I get these numbers very consistently.
84 4RUNNER,22R,HEDMAN,WEBER 32/36,Davis Unified Ignition,33" BFG
PHP: 7.4.33 Page Time: 9.950s Queries: 15 (0.004s) Memory: 0.6225 MB (Peak: 0.7215 MB) Data Comp: Off Server Time: 2026-06-22 01:07:03 UTC
