need some cherokee motor trans help for a friend #804772 04/12/07 03:04 PM
X
x89yjx Offline OP
a friend of mine put a 4.0 head and injection system on a 4.2(nothing new there) to install in his cherokee. once completed he called me and said the locating pins on the trans lined up and one bolt, but no others. i thought almost all the jeep motors were interchangeable? if i can put a 4.0 in my 89 4.2 wrangler, shouldnt he be able to put a 4,2 in his cherokee? the motor came from an 88 yj with the peugot. i think his cherokee is a 92...not sure. any help would be great
Re: need some cherokee motor trans help for a friend [Re: x89yjx] #804773 04/12/07 09:12 PM
BigJim Offline
Did he replace a 4 banger with that engine? If so the tranny will not fit.
Re: need some cherokee motor trans help for a friend [Re: BigJim] #804774 04/12/07 10:52 PM
X
x89yjx Offline OP
his cherokee had the 4.0 in it with an auto trans. he put his 4.0 head on the 4.2 taken from the 88 yj and tried to put it back in his cherokee. said the locating pins line up and one bolt, but none of the others. yj had a peugot
Re: need some cherokee motor trans help for a friend [Re: x89yjx] #804775 04/16/07 02:58 PM
X
x89yjx Offline OP
i guess he got it in. i didnt see any reason why it shouldnt work. any idea which pushrods to use? he's using the stock 4.0 ones now and it works but they need to be adjusted
Re: need some cherokee motor trans help for a friend [Re: x89yjx] #804776 04/16/07 03:20 PM
BigJim Offline
The adjustment in those pushrods is to purchase OVERSIZE rods. If he is hearing a clicking sound it may be the fuel injectors and not the valves..
Be very careful and do NOT install oversize rods for a lark! Make sure of the noise... Rods too long will burn valves..
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6032 MB (Peak: 0.6669 MB) Data Comp: Off Server Time: 2026-06-24 15:24:18 UTC
