Need info on ford 9" third member
#805466
04/15/07 04:21 PM
Is there a drawup with the dimension, location of studs, and size of the fit up of the 9" thirdmember. Im making my own 9/60 combo axles for my tacoma and im doing preliminary design features of the axle. Basicly I need a blueprint drawing of it. I just dont wanna have to get a 9" third yet. I want to be able to build the houseing and then be able to weld the plate on the back of the diff with the correct size hole.
=) gotta love being a fabricatior.
-Crash
Welding and Fabrication Engineer 2003 taco V6 ext cab sr5 1988 Toyota Pickup V6(totaled)
Re: Need info on ford 9" third member
[Re: CraShYota]
#805467
04/16/07 03:04 AM
I've thought about this before when I still had my jeep and came to the conclusion that building a full float 9" would be cheaper and just as strong.
Are you planing on fabing the whole thing or combining 60 axle tubes and a 9" (type?) third/pumpkin. <img src="/forums/images/graemlins/cheers.gif" alt="" />
"If you can't learn to do something well, learn to enjoy doing it poorly".
85 22RE, 5spd 4Runner project 87 Turbo Truck, Boost Controller, otherwise stock... for now. 86 Turbo 4Runner, Project
[Re: sindersblue]
#805468
04/16/07 05:02 AM
for the front everything but the third member and the 60 knuckles ill fab. Basicly the axle housing and all the link suspention mounts that get welded on. The rear will be the same diff housing but i havnt decided what kind of rotors i want to use yet so that could change. Ill just get bobby long to make me a set of custom shafts.
-Crash
[Re: CraShYota]
#805469
04/16/07 07:24 PM
I'd go out and get a third realy. Measuring is great and all but it's hard to beat seeing how it will work when all the components are there. If you want some ideas/inspiration check out these guys. Some prety cool stuff. <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6027 MB (Peak: 0.6588 MB) Data Comp: Off Server Time: 2026-06-12 19:44:08 UTCValid HTML 5 and Valid CSS
