Bad head gasket? #805901 04/16/07 11:50 PM
2
2timer Offline OP
After shuting off the engine, coolant is exiting the overflow resevior. Gurgling sound and then the coolant loss. Even after a relatively short trip around the corner.
I put in a new OEM thermostat. Problem still exists. Exhaust leaking through the HG perhaps? Thoughts? Thanks
Re: Bad head gasket? [Re: 2timer] #805902 04/17/07 02:14 AM
sasnydley Offline
It's a good possibility. Mine did that esp when ran hard, Than one day she just completely let go. Now I have nice new clearwater NEW casting heads. I live in florida so I drove to clearwater. Cost 481 bucks with exchange. Nice people But they ticked me off when they found out I was doing this myself-the guy started acting like a jerk and said I should leave it to the "professionals". <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Bad head gasket? [Re: sasnydley] #805903 04/17/07 04:01 AM
ghostraider Offline
you know...the last couple outings we have been on....when i really power the engine up a nasty hill ....or when i was jammmin up sand dunes too fast .....the raiders temp guage goes into the upper 3/4 area ....gurgling and coolant loss thru resevoir also ...seemed ok rest of day
I drive the vehicle very hard but this seemed odd.
how do you verify a blown head gasket??....a leak down test?...only about 60,000 miles on rebuilt motor
Re: Bad head gasket? [Re: ghostraider] #805904 04/17/07 05:17 AM
Oyaji_Jon Offline
I thought I read something about a coolant test you could do for exhaust. I could quite possibly be on crack, but...
I'm sure one of the gurus will chime in and help you out.
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Bad head gasket? [Re: Oyaji_Jon] #805905 04/17/07 11:35 AM
Y
yankneck696 Offline
If a friend has a radiator pressure tester, you can use that to check for overpressure. Otherwise, you need an expensive kit to sense hydrocarbons in the coolant.
Ed
Yankneck = Yankee ingenuity with Redneck stupidity.
"How can I break it better?"
89 Raider 3.0 w/ 31's for now
Re: Bad head gasket? [Re: 2timer] #805906 04/17/07 02:37 PM
2
2timer Offline OP
My hunch is that exhaust is presuring the coolant, and releases a cup or two of coolant after shutting off the engine. The temp guage has always read normal.
Anybody know a good Mits mechanic near the Wasatch front (wanted to ask for a long time)?
Thanks
Tim
Re: Bad head gasket? [Re: 2timer] #805907 04/17/07 06:30 PM
sparkem Offline
Run truck, make sure the pressure is out of the rad (very important or you could burn yourself bad), open ,and smell. I could smell the exhaust in my rad. I could also see black stuff floating in coolant. I had to do the head gaskets on both of my Monteros. One I would lose coolant through the overflow when running on interstate. Fine around town.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6188 MB (Peak: 0.6940 MB) Data Comp: Off Server Time: 2026-10-28 18:12:40 UTC
