OE 15x6 wheel offset #806278 04/18/07 02:53 AM
pucci Offline OP
are these neutral like the 15x7?
thanks
2.6 Trooper
2.0 Impulse Turbo
Re: OE 15x6 wheel offset [Re: pucci] #806279 04/18/07 08:32 PM
Shovel Offline
Casting on the back of them says OFFSET 30 (the top ones, off 88-91 troopers) and the wheel mounting surface lies about 4" (not a precision measure, just eyeball from tape measure) from the inboard edge.
I sent you an email separately with that info, but I figured I would post it here too for everyone's information.
Re: OE 15x6 wheel offset [Re: Shovel] #806280 04/18/07 09:57 PM
rodeo157 Offline
anyone run a 31" tireon a 15x6 or is the wheel to small? i know the bfg says do not mount on 6inch rim
95 rodeo 3.2 liter 5 speed 4 wheel drive. 2" lift. poly bushings. 2 1/4 manderal bent exhaust flow master muff. asin manual hubs, relocated ball joints, custom air intake system
92 rodeo 3.1 2wd auto (wifes)
Re: OE 15x6 wheel offset [Re: rodeo157] #806281 04/18/07 11:21 PM
Shovel Offline
I've run 31x10.5 tires on 6" rims for over 150,000 combined miles and find it a very agreeable combination... a 7" rim is a bit nicer and 8" is almost too wide, if you're going to air down.
However - running a combination specifically recommended against by the tire manufacturer will probably void your tire warranty and may leave you liable in certain legal situations.
I read on another forum of some guy who ran 31x11.5 tires on 6" rims and got very unfavorable wear patterns, but I had no such problem with 10.5" tires.
(edit - did the math on how much I've driven on 31's & 6" rims)
Re: OE 15x6 wheel offset [Re: Shovel] #806282 04/20/07 04:38 AM
pucci Offline OP
thanks for the info
I wonder if there is any problem clearing the 93+ front brakes?
2.6 Trooper
2.0 Impulse Turbo
Re: OE 15x6 wheel offset [Re: pucci] #806283 04/20/07 05:17 AM
Shovel Offline
thanks for the info
They fit an 01 vehicross smile does that help?
Re: OE 15x6 wheel offset [Re: Shovel] #806284 04/20/07 06:14 AM
pucci Offline OP
sounds good, my front brakes are a mix mash of VX and 2G Troop/Rodeo parts
2.6 Trooper
2.0 Impulse Turbo
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6133 MB (Peak: 0.6925 MB) Data Comp: Off Server Time: 2026-11-04 16:42:38 UTC
