Page 1 of 5 1 2 3 4 5
Custom crawler hauler #806939 04/20/07 11:57 PM
houlster Offline OP
Isuzu Moderator
Okay, so it's not going to be my "ultimate trailer". I found out about 10 days ago that the trailer I was gonna borrow again this year won't be available any more.
I have been updating and have pretty much decided what trailer to build, but I have nowhere near the time to do it. So, plan B. I drew this up this week. It's a bit single-purpose, but it's a lot simpler to build, half the cost and is still tons better than flat-towing.
7k axle, maybe torsion
3500 lb rated wheels/tires
4x2 tube frame, 2x2 wheel pockets
~900ish lbs w/ spare
will fit from a 90 to 118" wheelbase
axle can slide 6"
expaned metal wheel pocket floors (not shown)
wheel pockets about 14" off the ground (more like 12" with torsion axle)
5' tongue to pull & back a little easier
With the axle in the middle position, it'll give about 12% tongue weight with the Amigo loaded up. The forward spare isn't really a spare. It's really a storage box to hold chocks, straps, etc. It just *looks* like a spare. <img src="/forums/images/graemlins/wink.gif" alt="" />
Think I can finish in 3 weeks? I might possibly be able to beg/borrow one, but I really don't want to. Steel should be here in about an hour. 'Tis going to be a busy weekend... <img src="/forums/images/graemlins/scared.gif" alt="" />
Small details like gussets and tie-down points aren't all in yet. Whaddya think? (I mean, other than pointing out there's only 1 axle under it)
--Dan
Re: Custom crawler hauler [Re: houlster] #806940 04/21/07 12:08 AM
Jonesy Offline
Sounds and looks pretty cool...why not double axle? Simplicity I take it.
Keep us updated.
Steve
'97 Rodeo
3.2L V6
DOR 3" lift, 3"BL, DOR Boulder Bars, Tera-Low's, 33x10.5,Surco Safari Rack, Cobra CB, Rancho 9000's....andnNow with Half-Doors for the summer
Re: Custom crawler hauler [Re: houlster] #806941 04/21/07 03:06 AM
strawmyers Offline
Isuzu Moderator
It's a bit single-purpose... Whaddya think?
I think it will be great for the real reason you're building it. You can always add some tabs for bolting down sheets of plywood to the middle section if you want to haul other stuff. (obviously with a hinged access panel for getting to the spare. You could also use the expanded metal there if you're feeling independently wealthy... last I checked that stuff carried a surprisingly high price tag. Good luck! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Sean Strawmyer
Re: Custom crawler hauler [Re: strawmyers] #806942 04/21/07 04:06 AM
da_z_man Offline
what program did u make that on
99 rodeo 2wd
3"body lift
3" suspension
Aussie Locker
PROCOMP ES-9000
Re: Custom crawler hauler [Re: da_z_man] #806943 04/21/07 04:16 AM
Richard Saylor Offline
I'm pretty sure it's solidworks, IIRC.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: Custom crawler hauler [Re: Jonesy] #806944 04/21/07 04:35 AM
houlster Offline OP
Isuzu Moderator
I'm trying to keep to the minimalist approach. Tandem will add a few hudred $$ and lbs. The biggest problem is the rear axle of the Amigo will need to be between the rear tires on the trailer. Means I can't do a drop-deck and would have to make it wider. I would like a dually, but they're stupid expensive.
Re: Custom crawler hauler [Re: strawmyers] #806945 04/21/07 05:03 AM
houlster Offline OP
Isuzu Moderator
It's in the plans, but not before Moab. Outer supports on the wheel pockets, some cross-beams from small tubing and a plywood floor & I can use it as a flatbed for other stuff. It'll probably all store between the frame rails so I can set it up after unloading for a raised tent platform if I ever do over-nighters.
Re: Custom crawler hauler [Re: houlster] #806946 04/22/07 07:27 AM
StinkBug Offline
I know you've already done a lot of calculations on this (I know you too well to assume otherwise) but I've gotta say a tandem axle is gonna handle WORLDS better, especially with your somewhat lightweight tow rig. Going over dips and rollers on back highways can get a bit sketchy with that much weight on a single axle. Even with proper tongue weight they really like to porpoise on uneven roads at speed. Another nice thing with tandems, besides how the suspension stabilizes them is if you blow a tire the trailer still tows ok. With a single axle, and the weight of your amigo, I'd really hate to see a tire blow. Trailer tires also aren't exactly known for durability. My trailer probably has less than 10k miles on it and I've blown at least 4 tires now, and they were brand new with the trailer. The last one lost the entire tread layer and I unknowingly drove it that way for over 100 miles on the way to Globe.
I'd do something similar to what wayne did with his buggy trailer, except make the deck a little taller for easier drive over the axles. His trailer is light enough to push around the parking lot by myself, and handles like a dream, even behind his mini-van.
Dallas
[color:"blue"]Crew Chief, RedBull RockCrawling Team [/color]
[color:"red"]StinkyFab Custom Metal Creations[/color]
Project StinkBug
Re: Custom crawler hauler [Re: StinkBug] #806947 04/22/07 07:43 AM
StinkBug Offline
Here's a couple pics of the trailer I'm talking about for those who have no idea what I'm talking about. Wayne needed it to be lightweight, and it needed to be narrow and low enough to park inside his single car condo garage WITH the buggy on it.
For Dan I'd raise the deck a bit, and lower the fenders a little, as a normal vehicle would have a difficult time fitting over waynes fenders. They were built about 3" too high by accident.
Dallas
Project StinkBug
Re: Custom crawler hauler [Re: StinkBug] #806948 04/22/07 05:58 PM
CPOM Offline
Does he even need the tie downs? <img src="/forums/images/graemlins/lol.gif" alt="" /> Looks like its not going anywhere. Cool.
CHRIS
98 Amigo, 92 Pup
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6482 MB (Peak: 0.7726 MB) Data Comp: Off Server Time: 2026-10-27 01:55:06 UTC
