Page 3 of 5 1 2 3 4 5
Re: Custom crawler hauler [Re: houlster] #806959 04/29/07 06:53 AM
houlster Offline OP
Isuzu Moderator
Ok, so I'm feeling much better about the tandem axles now. Current progress:
Anyone recognize the wheels??? <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Custom crawler hauler [Re: houlster] #806960 04/29/07 02:16 PM
Curtis Johnson Offline
Did you use the front 2 wd Rodeo spindle assembly or buy an axle with the toyota pattern?
I'e got 4 of those Rodeo spindles and was planning to use them for another trail trailer I have in the back of my mind. Something like Gilbert did.
Looks good Dan. And as usual, your shop is too clean.
One of these days I'm going pour a concrete apron in front of my shop to keep the dirt off the floor.
Now as for all the junk on the floor, I have no idea how to keep it off the shop floor. I'm a slob at heart. <img src="/forums/images/graemlins/smile.gif" alt="" />
Curtis
Oh and before I forget.
Needs more triangleization! <img src="/forums/images/graemlins/lol.gif" alt="" />
Just call me The Gadget Master!![/b]
CurtisDrew@AOL.com
Re: Custom crawler hauler [Re: Curtis Johnson] #806961 04/29/07 03:29 PM
strawmyers Offline
Isuzu Moderator
Wrong forum, Curtis <img src="/forums/images/graemlins/lol.gif" alt="" />
Sean Strawmyer
Re: Custom crawler hauler [Re: Curtis Johnson] #806962 04/29/07 06:12 PM
houlster Offline OP
Isuzu Moderator
Standard trailer parts, but I got the 6-lug pattern which isn't all that common for 3500 lb axles. The wheels I bought from Randy like 10 years ago or more. IIRC, they came off George R's Amigo originally.
Now that's the first time I've ever been accused of having a clean shop. <img src="/forums/images/graemlins/lol.gif" alt="" /> What you're not seeing is the 3rd car bay that is literally a pile with a path through it...
--Dan
Re: Custom crawler hauler [Re: houlster] #806963 04/30/07 03:31 AM
lttlbddy Offline
path = unused storage space
Re: Custom crawler hauler [Re: houlster] #806964 04/30/07 04:31 AM
--Dan
Hell Dan.. I've got 3,000 square feet of shop and it's still has paths through the stuff all over it.
If I had 6,000 sq feet it would be the same thing.
CurtisDrew@AOL.com
Re: Custom crawler hauler [Re: houlster] #806965 04/30/07 07:50 AM
houlster Offline OP
Isuzu Moderator
Few more of the wheel pocket frames.
Still up are wheel pocket crossmembers, some gusseting (for Curtis smile ) and the spring hangars & I can flip it over and get it on it's axles.
Re: Custom crawler hauler [Re: houlster] #806966 04/30/07 03:55 PM
Paddler Offline
I'm just curious of the build cost Dan. Do really save that much building it as opposed to buying something comparable or is it more just a "I built it my way" thing. Steel is really getting up there in price.
1995 Honda Passport;
Some people wait a life time for their ship to sail in, while others simple grab the oars and begin paddling
Yours truely
http://www.zutah.com
Re: Custom crawler hauler [Re: Paddler] #806967 04/30/07 04:46 PM
houlster Offline OP
Isuzu Moderator
It's definitely not cheaper, unless you've got some of the parts already. Tandem 3500 lb axles with brakes, springs, u-bolts & hanger kit were $750. Tires (5) & a set of lug nuts was another $500. You could probably find a used 16' for not much more than that. Things like the coupler, jack, breakaway, lights, & wiring add several hundred more.
Steel wasn't that bad for this. About $400. My biggest problem is that I can't get a standard 16' trailer through my RV gate. Anything a little narrower I found was a lighter duty utility or heavy equipment type trailer.
--Dan
Re: Custom crawler hauler [Re: houlster] #806968 05/01/07 05:52 PM
houlster Offline OP
Isuzu Moderator
Actually, I'm going to recant my previous statement. Something didn't sound right after I wrote that & it's not adding up to as much as I thought at first. A new 16' flat bed with a spare is about $2800 out the door around here & I'll be well below that. On my 16' rollback I had planned, I was figuring about $3k in parts, but it'd be a lot more trailer than a standard 16'.
A good 16' a year or two old is going for $1800 - $2000 here, and older ones that will likely need at least tires and a little TLC is about $1200.
Anyways, point is, the steel isn't really the big cost of the trailer. It's maybe 1/4 - 1/3 of the total cost.
--Dan
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6490 MB (Peak: 0.7566 MB) Data Comp: Off Server Time: 2026-05-29 22:15:35 UTC
