i cant figure this out #807029 04/21/07 04:19 AM
MrCrowley Offline OP
bought a 96 grand cherokee. the onlt thing that sucks is that it is 2 wheel drive which i hate. but its paid for. i need to change a front blinker bulb and i can figure out how to get lens out so i can get the bulb out cause you cant get it from under the hood or for underneth. anyone know that i need to do to get it out. i need to get this fixed so i can tag the thing.
Re: i cant figure this out [Re: MrCrowley] #807030 04/21/07 01:10 PM
9
93yj Offline
I'm pretty sure it comes out from behind the headlamp assembly...pop your hood and see if you can find any wires that run directly into the backside of the assembly.
They should be connected to a "socket"...you'll see it, it'll be round. Twist this socket counter-clockwise and pull it out...the bulb will be plugged into this. Now pull the bulb out. This SHOULD be how it's designed.
Re: i cant figure this out [Re: 93yj] #807031 04/22/07 06:06 AM
ok im not totally stupid i did all of that if you read what i had on there i looked under the hood there are wires down there but they go through the core support through a hole about the size of a nickel and i cant get my fingers through there. do i need to pull out the whoe plastic head light to get it out or what do i need to do?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5911 MB (Peak: 0.6439 MB) Data Comp: Off Server Time: 2026-06-06 06:55:50 UTC
