vibration #807292 04/22/07 06:58 PM
turkbodiddle Offline OP
The other day took my truck on the freeway and when I got up to speed noticed a vibration. Try to decribe it. Pretty hard vibration gear shift clutch pedal. I know it has nothing to do with tires balancing, when I push clutch in going about 65 the noise and viration goes away. Would the flywheel cause such a vibration. Like I stated when you push clutch in it goes away at 65 the steering has no vibration so it can be somthing in the drivetrain? It does have a 3inch body lift, and for some reason there was a couple of tranny mounts not put on. Could this be the problem. Driving around town and in the hills no problem.
86 toy 33's custom camo paint dura liner black steels 3 inch lift stock motor
Re: vibration [Re: turkbodiddle] #807293 04/22/07 07:47 PM
OOP'S Offline
If this is a stock tranny and t-case there is only one mount. If you mean the bolts that hold the mount to the t-case and x-member and the x-member to the frame, replace them.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
PHP: 7.4.33 Page Time: 1.219s Queries: 15 (0.004s) Memory: 0.5869 MB (Peak: 0.6356 MB) Data Comp: Off Server Time: 2026-05-31 14:26:27 UTC
