How do I find a draw?... #807324 04/23/07 02:49 AM
O
Omega Supreme Offline OP
I have had my battery checked by schucks, they say its ok. I leave my truck for a week and its so dead not even the clock works. How can i trace this, also what is a common draw that affects our trucks? Its a 1987. Nothing special. Its really driving me nuts,, when it does run my alternator is working fine.
Re: How do I find a draw?... [Re: Omega Supreme] #807325 04/23/07 02:59 AM
grandeyota Offline
Use an ammeter and see what draw is getting pulled from your battery. It should be somewhere around .4 or so I think from the clock or radio or whatever. . If it's more than that, pull a fuse and see if it drops. If not move to the next fuse and see if thats the one drawing the current. Repeat until you find it. <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Fur clog in the sausage grinder
Re: How do I find a draw?... [Re: grandeyota] #807326 04/23/07 03:03 AM
O
So just plug put it on the positive and see if it makes any effect? How do fix when i find it? Thank you for the help!! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: How do I find a draw?... [Re: Omega Supreme] #807327 04/23/07 03:08 AM
grandeyota Offline
Yeah just put the ammeter on the positive side of the battery (all the + cables).
As far as fixing it, it's going to be different depending on what you find so when you find it, post up!
Re: How do I find a draw?... [Re: Omega Supreme] #807328 04/23/07 03:30 AM
4Crawler Offline
You put the ammeter in series with the battery. So pull the + cable off then connect the ammeter between the battery + post and the + battery cable.
Re: How do I find a draw?... [Re: 4Crawler] #807329 04/23/07 04:43 AM
Nix_Toy Offline
It doesn't matter if they say that it checks good. I had a battery in my truck that would discharge completely, every day.. about 24 hours time. Well, I would get it charged at Checkers, and they would check it after the charge and say it was good. Well, I did that for about a week. I was getting a little angry, because my battery was under warranty, so one day, I took the battery in to get charged.. I called them about an hour later and told them to hold my battery for a day, because I had to go to work. Well, I went in the next day to pick it up.. they said it was good to go, and I told them to check it (since it was sitting for a day) And sure enough, it was bad... I got a free new battery! Ha, they weren't happy! smile
Re: How do I find a draw?... [Re: Omega Supreme] #807330 04/23/07 04:54 AM
Davepet Offline
Do the ammeter test as described in here, that way you *know* your rig is or is not the problem. You can also just leave the battery disconnected for a week, check the voltage daily & see what happens.
BTW, a shorted diode in your alternator can produce your symptom.
Dave
Re: How do I find a draw?... [Re: Davepet] #807331 04/23/07 05:05 PM
O
Where can i get an ammeter? i have a voltage tester, and an ohm meter.
Re: How do I find a draw?... [Re: Omega Supreme] #807332 04/23/07 05:17 PM
4Crawler Offline
I mainly use one of Harbor Freight's inexpensive meters (great buy when they hit $2.99):
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=90899
It has a 10 amp (DC) current range and works fine for this sort of stuff. A 1-2 amp drain will kill a good battery in a day. I recently found a ~200mA drain in my '85, the on-board welder control box had been switched on accidentally and the indicator light on it was on, killing the battery in a few days.
Re: How do I find a draw?... [Re: 4Crawler] #807333 04/23/07 05:28 PM
O
I have one of those, what do i set it to to measure current? I have only used it to measure my battery and alternator output.
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6394 MB (Peak: 0.7593 MB) Data Comp: Off Server Time: 2026-06-03 18:19:57 UTC
