Sprung weight... 98 rodeo
#807670
04/24/07 02:00 AM
Anyone have any idea what the unsprung weight of a 98 rodeo is? in the rear is what i'm looking for.... anyone... anyone... Buler???
1998 Isuzu Rodeo -- slightly modified.
Re: Unsprung weight... 98 rodeo
[Re: trav]
#807671
04/24/07 02:07 AM
Unless I'm WAY off base here, unsprung weight is in reference to weight not supported by the suspension ie: wheels,tires,axles, etc. So unsprung weight can vary greatly with different wheel tire combinations. Just the new guys two centavos. <img src="/forums/images/graemlins/baby.gif" alt="" />
Larry W - 99 VX s/c 3" lift w/trimming & BFH mods, rollin' on 33/12.50x20" Nitto Mud Graps. Indy 4x h-d tie rods, lower links & a bunch of other stuff that put the hurt on the wallet.
[Re: Ldub]
#807672
04/24/07 02:14 AM
DANG IT! i hate it when I'm wrong in front of other people.. ha ha ha..
OK let me amend that... I'm wanting to know the weight of everything supported by the springs. So anything from springs down is out, everything from springs up is in! Does that make sense????
[Re: trav]
#807673
04/24/07 02:44 AM
You could take it to a scrap metal recycling type place & weigh it, then guesstimate how much less it weighs without axles,wheels,tires, etc. After seeing the depth of knowlege around here, I'm guessing someone knows how much axles & stuff weigh.
[Re: Ldub]
#807674
04/24/07 03:05 AM
Isuzu Moderator
That'd be a good place to start depending on how exact this needs to be. Most truck stop gas stations (Flying J, etc) have scales as well. Weigh the whole truck and then subtract 600-700# for the axles and tires. Not sure what to think about this new guy... might be a good idea just to ban him now <img src="/forums/images/graemlins/pfft.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Sean Strawmyer Back and ready to rock...... crawl. From Indiana or surrounding states and interested in wheelin'? Check out www.mwior.com
[Re: strawmyers]
#807675
04/24/07 03:12 AM
I'm trying to find a place to start when getting these springs for my coilovers. so i need just the rear... any ideas? just the rear tires on the scale?
[Re: strawmyers]
#807676
04/24/07 03:52 AM
Not sure what to think about this new guy... might be a good idea just to ban him now <img src="/forums/images/graemlins/pfft.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> Hey...I rather doubt I'll need any help from you in that regard. <img src="/forums/images/graemlins/notooth.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> Check your driver side door jamb, there is a sticker that gives front & rear axle weights. You should be able to figure percentage f/r with that info.
[Re: Ldub]
#807677
04/24/07 04:02 AM
I actually thought of that too, however the truck is not here right now. I have it at my buddies and i'll not be going there for a day or two... i need to get these springs on the way!!!
[Re: Ldub]
#807678
04/24/07 06:07 AM
Isuzu Moderator
I am pretty sure those numbers are weight ratings, not curb weights. Generally useless with regards to the actual weight of the vehicle.
Sadly, the best/only way to do this is to get it weighed front and rear and go from there. Don't forget the full tank of gas and you in the driver's seat. You should also account some for being fully stocked for a trail run. Anything less and you are liable to squat bad when loaded.
Good Luck, Michael
[Re: mlclark]
#807679
04/29/07 01:14 AM
I have a 99 rodeo rear axle sitting on the floor of my garage, I would guess its about 150-200 lbs. I can readily pick up one end, picking up the whole thing is out of the question (for me atleast).
Tires...100 or so lbs ea w/wheels
-Mike
Mike Walter '98 Amigo well used '94 Rodeo in need of help '99 Ram CTD for hauling feather pillows '01 unheated shop
