rear end 3rd member question #807856 04/25/07 01:54 AM
V
v8yota Offline OP
will a rear 3rd member and axles from a 1990 4 runner fit in a 1993 pickup housung,,the 4runner 3rd member is the 4 pinion support,,,,,,,thanks for the help
Re: rear end 3rd member question [Re: v8yota] #807857 04/25/07 01:56 AM
4Crawler Offline
Yep on the 3rd. On the axles, the brake backing plates are different between the coil and leaf sprung trucks. I think parts are swappable, but would require pressing off the bearings and pressing them back on.
Re: rear end 3rd member question [Re: v8yota] #807858 04/25/07 02:23 AM
jasonmt Offline
The coil sprung 4Runner axle shafts are ~3/8" longer than the leaf sprung axles and may bottom out in a leaf sprung housing before the bearing retainer makes contact with the housing.
Re: rear end 3rd member question [Re: jasonmt] #807859 04/25/07 10:56 AM
V
v8yota Offline OP
could i use the truck axles with the 4 runner 3rd member
Re: rear end 3rd member question [Re: v8yota] #807860 04/25/07 03:17 PM
4Crawler Offline
Yes, you should be able to. As I posted, the 3rds swap just fine.
PHP: 7.4.33 Page Time: 1.253s Queries: 15 (0.006s) Memory: 0.6056 MB (Peak: 0.6695 MB) Data Comp: Off Server Time: 2026-07-13 09:49:58 UTC
