Page 1 of 3 1 2 3
Is there a good idler arm yet? #807907 04/25/07 06:00 AM
KrzyDav Offline OP
Looks like I'm about to put on my 4th one.
Has anybody tried to machine some bronze bushings , or something. My bushing on the idler are allowing some verticle slop again , giving sloppy steering.
dave h.
Re: Is there a good idler arm yet? [Re: KrzyDav] #807908 04/25/07 01:04 PM
FrankR Offline
KevinC made one that looked very good - send him a PM and see if he has another. A few folks have replaced the idler bracket with another steering box on the passenger side.
Frank
Re: Is there a good idler arm yet? [Re: KrzyDav] #807909 04/25/07 04:13 PM
87Montero Offline
Bob Shaw developed a way to 'recycle' his by tossing it in his press every time it gets sloppy and getting rid of the play. I can't describe it but it made perfect sense when he showed me in person.
Re: Is there a good idler arm yet? [Re: KrzyDav] #807910 04/25/07 05:25 PM
LRJ4x4 Offline
What size tires? Where are you getting the parts from?
Re: Is there a good idler arm yet? [Re: LRJ4x4] #807911 04/25/07 05:31 PM
LandRaider Offline
Put a steering box over there. smile <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Is there a good idler arm yet? [Re: LandRaider] #807912 04/26/07 01:13 AM
sparkem Offline
His post is serious. Nittberg (sp?) did it.
Re: Is there a good idler arm yet? [Re: sparkem] #807913 04/26/07 02:11 AM
sparkem Offline
Re: Is there a good idler arm yet? [Re: sparkem] #807914 04/26/07 02:43 AM
L
Lester Offline
I did it but it started to fail when the centre spindle(if that's what it's called) started getting dry cos the welding wasn't perfect and there was a hole in the back plate welded on. Grease wasn't packing in properly. I went back with a proper idle arm and a bracket to hold in in place. Moreover with the steering box, I noticed there was more wear and tear in the other steering ball joints than with the idle arm.
Re: Is there a good idler arm yet? [Re: Lester] #807915 04/26/07 04:45 AM
The wear parts on the idler arm are generally the bushings, right? I've read a long forgotten post where someone carried spare bushings obtained from the dealer... <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Is there a good idler arm yet? [Re: rxinhed] #807916 04/26/07 03:44 PM
You need one of Kary's lower idler arm braces. Greatly reduces bushing slop
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6385 MB (Peak: 0.7624 MB) Data Comp: Off Server Time: 2026-06-10 17:59:29 UTC
