Re: Is there a good idler arm yet?
[Re: fasteddy]
#807927
05/01/07 04:42 AM
Try Moog -----They seem to last longer
1990 Montero LWB V6 5-SP Locked Rear/33/12.50 Kumho KL-71 Mud Terrains/3" body lift,bars/springs/poly/shocks/custom skids/lots of lights/snorkle/etc......
[Re: fasteddy]
#807928
05/01/07 08:07 AM
F.E., Lloyd Swartz used to run one, but with generally negative reports...could maybe have been from hard use/lack of maintenance, though. He was/is running 35's, also.
[Re: off-roader]
#807929
05/04/07 01:24 AM
What is the part # for Mitsu brand bushings?
There isn't a dealer in these parts so I have to order from rockville. \ I run 31s and use the Raider daily use ,,,very little off road.
As for using a steering box , don't you have to use an English right hand side box??
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
[Re: KrzyDav]
#807930
05/04/07 04:42 AM
CAPS shows 2 part numbers
PNC: 47105 Part No: MB243982 & MB 673524 Name: Bushing, Steering Lin <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: off-roader]
#807931
05/04/07 12:00 PM
For steering box use, just mount it in the 3 holes for idler arm & swap the pitman arm 180 degrees. Might need some disassembly, too.
Ed
Yankneck = Yankee ingenuity with Redneck stupidity. "How can I break it better?" 89 Raider 3.0 w/ 31's for now
[Re: KrzyDav]
#807932
05/04/07 04:21 PM
The moog is just a re-packaged part from Japan. Mine did not last very long. I found that the factory arm and bushings held up better. From what I saw the factory bushings were a bit harder.
I dont have access to a lathe and a mill since I moved so I wont be converting any more arm for a while.
Kevin
[Re: Kevin C]
#807933
05/07/07 07:06 AM
kinda glad i came across this thread becouse i was about to purchase a complete idlearm asymbly from the dealership, gonna be my 2nd one in fact. i had no idea that the i can possibly replace the bushings inside. i was wondering if anyone has tried or thought of replacing the bushings with polyeurothane bushings. i always see those polyeurothane swaybar kits in different diameters at Pepboys and other parts store. maybe having that type of composition will hold up longer. does anyone know what the diameters are becouse i would like to look into it.
