Page 1 of 3 1 2 3
A/C recharge #807934 04/25/07 06:18 AM
redbull Offline OP
So, warm weather = hot Pajero. AC compressor runs fine, but barely cools below ambient. I bought a hose kit and one 6oz can of Duracool. My Pajero does not have the rear AC.
Anyone done the recharge and have any tips?
Re: A/C recharge [Re: redbull] #807935 04/26/07 09:06 PM
redbull Offline OP
No one done this yet? I think Phil did last summer.
It's getting warm out...
Re: A/C recharge [Re: redbull] #807936 04/27/07 12:57 AM
PHIL_ Offline
Sorry Ed, been super busy last few weeks, with no end in sight till end of June... you know how it is <img src="/forums/images/graemlins/wink.gif" alt="" />
I had my ac system topped up with said stuff last summer - its been awesome. Many imports I've seen come in have had empty systems that worked when topped up - kinda makes you think, doesn't it? <img src="/forums/images/graemlins/ignore.gif" alt="" /> Anyways, its worked like a charm ever since... kinda tricky to find the port, but its down there - strong flashlight helped...
Re: A/C recharge [Re: PHIL_] #807937 04/27/07 07:35 AM
redbull Offline OP
Thanks Phil. So, did you just use one whole can, or did you add slowly until you got a certain temperature difference from ambient?
Re: A/C recharge [Re: redbull] #807938 04/27/07 02:08 PM
PHIL_ Offline
Kind of both buddy. Buddy of mine was n the can, (not literally <img src="/forums/images/graemlins/lol.gif" alt="" /> ) and I was inside with the blower on hi - kept adding till it was chilly-cold, but it took the whole can. Apparently you don't wanna overfill, but in this case a can was about right.
Re: A/C recharge [Re: PHIL_] #807939 04/27/07 03:33 PM
redbull Offline OP
OK! I'm going to have at it this weekend.
Re: A/C recharge [Re: redbull] #807940 06/02/07 11:52 PM
redbull Offline OP
One month later and it's finally hot enough to get me to go outside and do this. Found a sight glass under the intercooler intake, and found a port on the top of the compressor. The port has a black cap and an "S" stamped on it. I'm guessing since this is on the top, that it's not the right port. Can't find a blue-capped port anywhere.
Do I have the right one? Where do I need to look?
Re: A/C recharge [Re: redbull] #807941 06/03/07 01:21 AM
redbull Offline OP
Little more flashlight work and there is a vertical port on top of the compressor. The "S" port I described earlier is horizontal.
So, I hooked her all up and it's very slow going! Idled for 30 minutes and the first can has not been completely taken in yet. I do see some bubbles in the glass. No change in cooling performance.
Re: A/C recharge [Re: redbull] #807942 06/03/07 02:31 AM
redbull Offline OP
And I have AC!!! <img src="/forums/images/graemlins/smile.gif" alt="" />
Gave all the connections a bit of a snug-up. The R12-R134 adapter had a good 1/2 turn left in it using my pliers and that seemed to do the trick.
Re: A/C recharge [Re: redbull] #807943 06/03/07 03:52 AM
Clead Offline
Good info. Thanks for sharing. <img src="/forums/images/graemlins/cheers.gif" alt="" /> I'd prefer that my A/C works off the boat, but if it doesn't, I've got this thread to come back to!
I am now officially a Pajero owner. <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />.
1992 Exceed w/winter pkg, roof tray, bounceys, the works smile
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 2.036s Queries: 16 (0.003s) Memory: 0.6368 MB (Peak: 0.7602 MB) Data Comp: Off Server Time: 2026-07-09 20:40:52 UTC
