Thrust washer question... #807969 04/25/07 08:40 AM
hellbound Offline OP
Hi there everybody, i have finished rebuilding my 4ze1 with new main/rod bearings, piston rings seals, thrust washers etc. Just want to know from those of you that have replaced the thrust washers, which is the correct orientation to install these. I was assumed that the "smooth" side faced the crank lobe and the other side, say the "notched" side faced the no 3 bearing cap??? can someone confirm this, much appreciated smile
Adam.
Re: Thrust washer question... [Re: hellbound] #807970 04/25/07 07:40 PM
mlclark Offline
Isuzu Moderator
It should go with the groves toward the crank. This allows for oil ingress and egress from the bearing surface.
Michael
Re: Thrust washer question... [Re: mlclark] #807971 04/26/07 10:44 AM
bugger it ! i think i MAY have put them in the other way around - grooves towards the cap and not the crank, is this a major dilemma ? <img src="/forums/images/graemlins/confused.gif" alt="" />
Adam.
Re: Thrust washer question... [Re: hellbound] #807972 04/27/07 02:22 AM
JLEMOND Offline
YES THEY MUST BE THE OTHER WAY OR YOU WILL BURN THEM OUT , AS YOU PUSH THE CLUTCH IN A FORCE THE CRANK SHAFT FORWARD THERE WILL BE LITTLE TO NO OIL ON THE SURFACE OF THE BEARING AND PRETTY SOON, YOU HAVE NO BEARING AND OR THE THRUST FACE OF THE CRANK GETS WORN DOWN, AND THAT ISNT A CHEAP FIX, AS MICHAEL SAID THE GROOVES MUST FACE THE CRANK JOURNAL FACE , JERRY
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6007 MB (Peak: 0.6562 MB) Data Comp: Off Server Time: 2026-11-14 16:12:15 UTC
