Brake lIne intermixing #807984 04/25/07 05:16 PM
Zubicon Offline OP
05 Rubi/Unl
I'm putting a 4" lift SA on my rig. Brake lines have to be extended because I don't want them being my limiting straps if you know what I mean. I will not ghetto it by bending my hardlines so I can relocate the mount lower down the frame rail. I don't want to buy some high end braided brake line extensions at the tune of $300.00 or close to. I heard that YJ lines will merry up with TJ lines. True??????? If so is there any other issues that I need to know such as only "X" year YJ lines will work, etc.
Any info will be hugely appreciated. I have 17 days left before Moab and I'm apprehensive about starting this prior to mostly due to this issue. Thanks, much obliged.
Re: Brake lIne intermixing [Re: Zubicon] #807985 04/25/07 05:29 PM
Zubicon Offline OP
Just got my question answered n another forum. Here's the answer if anyone else runs into this issue.
http://www.stu-offroad.com/suspension/exthose/brakes-1.htm
Re: Brake lIne intermixing [Re: Zubicon] #807986 04/25/07 08:18 PM
BobRowe Offline
You can get the brake lines you need from Stainless Steel Brakes Corporation for a reasonable price. Their web site is:
http://www.ssbrakes.com/
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.5910 MB (Peak: 0.6450 MB) Data Comp: Off Server Time: 2026-10-22 09:29:31 UTC
