Problem with ARB compressor
#808033
04/25/07 08:21 PM
Hello, Earlier in the year, i installed an ARB compressor into the trooper. Lately, I seem to be having an issue with it. I flip the switch and it kicks on to fill the little tank on it. After it reaches pressure and the pump turns off, it wont come back on. I think it tries to, but it ends up blowing the in-line fuse. Anybody have any thougts as to what is causing it? Thanks
'91 Trooper 3.4 V6, K&N, 33x12.5 Trxus MT's, Aisin hubs, 3" body lift, Rear ARB Naches Trail
Re: Problem with ARB compressor
[Re: Storm Trooper]
#808034
04/26/07 03:13 AM
I don't have an on board compressor, so take this FWIW...
Whenever I have a compressor plugged in to run nail guns etc. & it blows the breakers when it kicks in, it's always due to being plugged in to a circut that doesn't have enough amperage. I would assume this would work the same on a 12v dc system.
Just my FNG opinion.
Larry W - 99 VX s/c 3" lift w/trimming & BFH mods, rollin' on 33/12.50x20" Nitto Mud Graps. Indy 4x h-d tie rods, lower links & a bunch of other stuff that put the hurt on the wallet.
[Re: Ldub]
#808035
04/26/07 04:27 PM
Hmm. I'll check that out. The weird thing is that it worked fine for a while. I've got a question in to ARB, just waiting for a response.
[Re: Storm Trooper]
#808036
04/26/07 04:35 PM
It may be that your compressor is overheating, either because of an internal problem or because of where you mounted it.
Do you have the quick disconnect for inflating tires? If so, open the hood and then turn on the compressor. Use the disconnect to drain the tank to see if it will activate then. If it does, then you likely have an overheating problem.
[Re: Jim_Paget]
#808037
04/26/07 06:28 PM
Thanks Jim. I'll try that.
[Re: Storm Trooper]
#808038
04/27/07 04:21 AM
You're welcome, almost neighbor <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: Jim_Paget]
#808039
04/27/07 10:42 PM
Yeah, no kidding huh? Crazy thing is that I saw you more when I lived in Yakima 6 years ago. I went to walker valley a couple of months ago. IT was tough.
Anyway, back to the subject. I get a reply from ARB. I'm sending it back to them for a replacement.
[Re: Storm Trooper]
#808040
04/28/07 01:26 AM
I live about 1 mile from where you turn off Highway 9 to go to Walker Valley.
[Re: Storm Trooper]
#808041
05/04/07 06:26 AM
I just replaced mine. It overheated on my last run, and it melted at the first big connector leaving the ARB unit. I ended up replacing it, and redoing all the wiring while I was at it. I got 9 years out of it, so I'm not complaining.
Keith "AIR AMIGO!" aka 1994 Isuzu Amigo SAS with Toyota axles, 5.29's, dual ARB's, IROK's, WARN HS9500 winch, and etc. Pacific NW Isuzu Off-Roaders Timber Tamers #172
