Somethings wrong #808059 04/25/07 09:29 PM
tomzsix Offline OP
My Montero's alternator shows a charge of only 12 volts, my check EGR light and battery light come on faintly, and now my choke won't fully open when warm. My 2.6 is just falling apart. Whats wrong now??
Tom Tucker
Re: Somethings wrong [Re: tomzsix] #808060 04/25/07 09:36 PM
LRJ4x4 Offline
Electrical grimlins are the worst. The Montero has a good electrical system. I would start by checking all your connections and ground wires. Also check the fusable link.
Lock parts store can check your Alt for you.
Re: Somethings wrong [Re: tomzsix] #808061 04/26/07 01:37 AM
8
89IsMine Offline
Sounds like the voltage regulator is on its way out?
Eric W.
Re: Somethings wrong [Re: 89IsMine] #808062 04/26/07 04:59 PM
tomzsix Offline OP
I have had the alternator for 8 years. That could be the problem. But what operates the choke? Is it electric or hot water operated?
Tom Tucker
Re: Somethings wrong [Re: tomzsix] #808063 04/26/07 05:45 PM
LRJ4x4 Offline
electric
Re: Somethings wrong [Re: tomzsix] #808064 04/27/07 02:57 AM
sasnydley Offline
The alternator may be going south -should put out more than 12 volts. Mine died a slow painful death.
Re: Somethings wrong [Re: sasnydley] #808065 04/27/07 01:13 PM
DirtyOldTown Offline
If you've got a volt meter, check your battery voltage with the engine and all accessories off. It should be around 12.6 volts. Once you start the engine (again, all accessories off) it should jump up to the 13-15 volt range. There is more to it than this simple check, but it's easy and a good place to start. If you don't have a volt meter, you can get a cheap one at Harbor Freight for like five bucks.
'91 LWB, 31x10.5s, KYBs, A/T "I look like Robert De Niro, I drive a Mitsubishi Pajero" - Billy Bragg (not the original lyrics, but that's how he sang it when I saw him in Dublin in '04)
PHP: 7.4.33 Page Time: 0.397s Queries: 15 (0.003s) Memory: 0.6138 MB (Peak: 0.6908 MB) Data Comp: Off Server Time: 2026-06-04 14:43:12 UTC
