WHEEL LOCK #808605 04/28/07 02:27 PM
MATCHBOX Offline OP
Wheel lock light on dash is staying on. How is this light diffrent than the 4x4 light?
89 Raider cranked t-bars,summit shackles
98 Land Rover discovery
Re: WHEEL LOCK [Re: MATCHBOX] #808606 04/28/07 04:39 PM
sparkem Offline
Wheel lock light is telling you your hubs are locked, or something is tricking the light to stay on. The 4x4 litght is telling you you shifted into 4wd via the transfer case.
Re: WHEEL LOCK [Re: sparkem] #808607 04/29/07 01:24 AM
52degrees Offline
Just to expand on this a bit, the sensor for the wheel lock light is looking at front driveshaft rotation. So, unless there's a malfunction, the front driveshift is spinning while you are moving. If you have auto hubs, I'd try backing up a few feet till the light coes out. If you have manual hubs, check to make sure they are unlocked.
KG6VNX
Re: WHEEL LOCK [Re: 52degrees] #808608 04/29/07 03:31 AM
sparkem Offline
Ah, I see. I did not know exactly where the sensor was.
Re: WHEEL LOCK [Re: sparkem] #808609 04/29/07 03:49 AM
MATCHBOX Offline OP
Thanks for the info thats what I thought it was the auto hubs sticking
Re: WHEEL LOCK [Re: MATCHBOX] #808610 04/29/07 04:54 AM
Jamez Offline
Was there a consensus that if the light didn't work you're screwed? I thought I saw something about what to look for and possible problems. Anyone remember that?
'87 Raider w/rebuilt 2.6
Weber 32/36
Re: WHEEL LOCK [Re: Jamez] #808611 04/29/07 05:04 AM
52degrees Offline
<img src="/forums/images/graemlins/confused.gif" alt="" />
If the light doesn't work the light doesn't work. I don't need no stinking light to tell me I'm in 4wd.
KG6VNX
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6111 MB (Peak: 0.6891 MB) Data Comp: Off Server Time: 2026-06-10 02:41:39 UTC
