Re: Recovery points?
[Re: kiarazy]
#808963
05/04/07 02:13 AM
i'm very interested in the pictures of your front recovery points! i'm looking for ideas
02 [color:"red"] Sportie [/color] 5sp 4x4 2dr. 1?" Body + 4" Rocksportgear lifts, 31x10.50 Wildcats M/Ts, Manual Hubs, Yakima rack, basket. Redline gear oils http://www.cardomain.com/id/calapooyasMy beater, 03 Land Rover Freelander SE3
[Re: Calappoyas]
#808964
05/04/07 02:37 AM
![[Linked Image]](http://i144.photobucket.com/albums/r177/kiarazy/100_1915.jpg) the front will probally only work if you removed your front bumper or you might crush it ![[Linked Image]](http://i144.photobucket.com/albums/r177/kiarazy/100_1916.jpg) rear <img src="/forums/images/graemlins/patriot.gif" alt="" /> there rated at 10,000lbs
02 sportage softtop 1 inch body 4 inch suspension custom exhaust custom bumpers front and rear 31" tires
[Re: kiarazy]
#808965
05/09/07 02:08 AM
Front bumper is off. (bumpers are not required in Oregon <img src="/forums/images/graemlins/kewl.gif" alt="" /> ) bolts go all the way through or did you tap the frame?
[Re: Calappoyas]
#808966
05/09/07 03:06 AM
Hey Cal, What rims are u running????
Offset etc......
[Re: Hydra747]
#808967
05/09/07 04:09 AM
bolts go all the way through be careful of the radiator on bolt placement though because you will have trouble getting the nuts on i also put a 1/4 inch backer plate on opposite side of tow point to reinforce, she's rock solid as for the rear very simple lots of room
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6117 MB (Peak: 0.6769 MB) Data Comp: Off Server Time: 2026-06-22 02:40:13 UTCValid HTML 5 and Valid CSS
