Re: Recovery points? [Re: kiarazy] #808963 05/04/07 02:13 AM
Calappoyas Offline
i'm very interested in the pictures of your front recovery points! i'm looking for ideas
02 [color:"red"] Sportie [/color] 5sp 4x4 2dr. 1?" Body + 4" Rocksportgear lifts, 31x10.50 Wildcats M/Ts, Manual Hubs, Yakima rack, basket. Redline gear oils
http://www.cardomain.com/id/calapooyas
My beater, 03 Land Rover Freelander SE3
Re: Recovery points? [Re: Calappoyas] #808964 05/04/07 02:37 AM
kiarazy Offline
the front will probally only work if you removed your front bumper or you might crush it
rear <img src="/forums/images/graemlins/patriot.gif" alt="" /> there rated at 10,000lbs
02 sportage softtop 1 inch body 4 inch suspension custom exhaust custom bumpers front and rear 31" tires
Re: Recovery points? [Re: kiarazy] #808965 05/09/07 02:08 AM
Calappoyas Offline
Front bumper is off. (bumpers are not required in Oregon <img src="/forums/images/graemlins/kewl.gif" alt="" /> ) bolts go all the way through or did you tap the frame?
Re: Recovery points? [Re: Calappoyas] #808966 05/09/07 03:06 AM
Hydra747 Offline
Hey Cal, What rims are u running????
Offset etc......
Re: Recovery points? [Re: Hydra747] #808967 05/09/07 04:09 AM
kiarazy Offline
bolts go all the way through be careful of the radiator on bolt placement though because you will have trouble getting the nuts on i also put a 1/4 inch backer plate on opposite side of tow point to reinforce, she's rock solid as for the rear very simple lots of room
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6112 MB (Peak: 0.6765 MB) Data Comp: Off Server Time: 2026-06-23 04:50:00 UTC
