Page 2 of 4 1 2 3 4
Re: Scerb's SAS [Re: Scerb] #809206 05/12/07 11:22 PM
4xJedi Offline
Did you just take out the torsions then torch the brackets letting everything else fall? Trying to see what I need to unbolt/remove before cutting the main IFS horns.
'86 4Runner 5" SAS
'97 4Runner
'05 Corolla
'00 F250 PowerStroke
Re: Scerb's SAS [Re: 4xJedi] #809207 05/13/07 04:46 AM
Scerb Offline OP
lets see.. I unbolted the torsion bars/upper ball joints and that took care of the upper control arms. Then I unbolted the pitman arm, idler arm and steering stabilizer. Then I torched the four ifs brackets. Then I unbolted the rubber diff mounts and everything dropped out.
I ran the torch out oxygen half way through the first shackle tube hole <img src="/forums/images/graemlins/frown.gif" alt="" />. Is it possible to do those with a hole saw? I hope?
-Scerb
Re: Scerb's SAS [Re: Scerb] #809208 05/13/07 04:42 PM
4xJedi Offline
Yes, I bought a 2" hole saw, make sure it's bi-metal. Some vendors recommend a hole saw, but they say you'll still need a torch to blow out some webbing inside the frame.
'86 4Runner 5" SAS
'97 4Runner
'05 Corolla
Re: Scerb's SAS [Re: 4xJedi] #809209 05/14/07 12:54 AM
Scerb Offline OP
Never even gave the hole saw a try. I forgot I had cutting rods for my welder. They worked almost as good as the torch did. Got both shackle tube holes cut:
Three of the four holes I cut came out just about as tight as that one. The 4th is a little sloppy but will be fine.
Also cut the ifs brackets off a little closer, gotta grind everything down tomorrow:
And a pic of my work area just for fun. I'm out of the driveway because I gotta be up near the house to use the 230V welder.. I don't mind it much.
More tomorrow <img src="/forums/images/graemlins/kewl.gif" alt="" />
-Scerb
Re: Scerb's SAS [Re: Scerb] #809210 05/14/07 01:24 PM
ACES_HI Offline
-Scerb
Im not sure that I'd feel comfortable working under there with just the jackstands for support. If one slips youre done. <img src="/forums/images/graemlins/zombie.gif" alt="" /> I would personally use a hi lift on the front bumper for backup. Be safe....we dont wanna loose ya! <img src="/forums/images/graemlins/kewl.gif" alt="" />
'04 Taco x-cab 3RZ FE stock (daily driver)
'90 x-cab 22RE stock
'82 Hilux 6" lift (ACES HI)
'82 2-Hiluxs' Rally Edition (parts)
'81 Hilux 3" lift (parts/restore)
Re: Scerb's SAS [Re: ACES_HI] #809211 05/14/07 02:28 PM
Scerb Offline OP
ya, the jackstand looks pretty sketchy in that pic <img src="/forums/images/graemlins/lol.gif" alt="" /> Its not like that in person. Truck won't budge on the good ol' push test. Thanks for your concern though <img src="/forums/images/graemlins/cyclops.gif" alt="" />
-Scerb
Re: Scerb's SAS [Re: Scerb] #809212 05/14/07 05:47 PM
JAVYPRO Offline
Im not sure that I'd feel comfortable working under there with just the jackstands for support. If one slips youre done. I would personally use a hi lift on the front bumper for backup. Be safe....we dont wanna loose ya!
-Scerb
I agree, if I were you I will add some more support down there. You can at least place you tires one on top of the other under the frame or cross-member somewhere. <img src="/forums/images/graemlins/kewl.gif" alt="" />
I got two jack stands that hold 6 tons each and still I don't trust using them by themselves, What if whomever was in charge of placing the info sticker on them mixed them up and stick'em on the smaller stands <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: Scerb's SAS [Re: JAVYPRO] #809213 05/15/07 01:16 AM
lethe Offline
wheres your crank pully? <img src="/forums/images/graemlins/lol.gif" alt="" /> actually. do you even have the timing chain cover on it?
87' ext cab toy
Re: Scerb's SAS [Re: lethe] #809214 05/15/07 01:23 AM
Scerb Offline OP
I grenaded a tensioner somehow... Great service as always from EB - sending me a new one free of charge once he gets the pieces of my old one. This is what was in the oil pan <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
-Scerb
Re: Scerb's SAS [Re: Scerb] #809215 05/19/07 04:06 AM
Scerb Offline OP
Got the axle all painted and about halfway through the rebuild. Put a Detriot EZ locker in the rear axle, and put that welded diff in the front. The ring gear in my welded diff was missing three teeth so i replaced that too...
Not much progress on the actual frame - been raining too much <img src="/forums/images/graemlins/frown.gif" alt="" />
Nicest this axle will ever look again:
-Scerb
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6424 MB (Peak: 0.7532 MB) Data Comp: Off Server Time: 2026-06-09 10:08:48 UTC
