Page 3 of 4 1 2 3 4
Re: Scerb's SAS [Re: Scerb] #809216 05/21/07 01:19 AM
ChrisH Offline
wow guy, good goin looks great. smile
'95 Toyota Pickup DX Xtended Cab ~ Daily Driver
Re: Scerb's SAS [Re: Scerb] #809217 05/22/07 01:05 AM
Scerb Offline OP
Today was a pretty good day - FINALLY stopped raining, got a bunch more work done outside, and got hired for a job at the local lumber yard. They're gonna train me to use a forklift <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/ignore.gif" alt="" />
So axle is all assembled and lieing in front of truck:
I welded a 2" receiver tube into a notch in the Trail-Gear xmember:
And notched the factory crossmember, and started to grind the ends of the factory crossmember flat so the hanger fits nice and tight up against it:
Probably gonna go out and grind the other side of the crossmember flat and call it a day.
-Scerb
Re: Scerb's SAS [Re: Scerb] #809218 05/22/07 01:12 AM
ChrisH Offline
i see u got some tires under that beast now <img src="/forums/images/graemlins/wink.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
don't get smooshed. <img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: Scerb's SAS [Re: ChrisH] #809219 05/22/07 01:14 AM
Scerb Offline OP
thanks mom.
<img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: Scerb's SAS [Re: Scerb] #809220 05/23/07 02:18 AM
Scerb Offline OP
Truck is on all fours now <img src="/forums/images/graemlins/smile.gif" alt="" />
Those springs better settle a good 4inches...... if not I'm taking out a leaf to lower the front. The 3" body lift is coming out, btw (before i do shock hoops).
Tacked the crossmember on first, then put the axle in and set it down to check shackle angle. Notice the nice tight fit between the factory and TG crossmembers <img src="/forums/images/graemlins/kewl.gif" alt="" />
Shackle was vertical which is what it should be I guess since the springs are new:
Welded the crossmember on, getting better still with the welding - I'm happy <img src="/forums/images/graemlins/cyclops.gif" alt="" />:
Dark pic, but this is how it sits now. Still gotta weld the back of the crossmember, shackle tubes, motor mounts. I am gonna get a FROR severe use front crossmember brace and weld that on, and do some additional bracing to the receiver tube.
-Scerb
Re: Scerb's SAS [Re: Scerb] #809221 05/23/07 10:51 AM
4xJedi Offline
How far forward did you mount the spring hanger? Almost looks flush. Did you grind down the bottom of the body mounts to get the 'tight fit' on the hanger? I thought about doing that.
I like the 2-tone look you've got going on with the axle. Just spray clear all over the bare add-ons and be a rolling ad for TG <img src="/forums/images/graemlins/smile.gif" alt="" />.
'86 4Runner 5" SAS
'97 4Runner
'05 Corolla
'00 F250 PowerStroke
Re: Scerb's SAS [Re: 4xJedi] #809222 05/23/07 03:40 PM
Scerb Offline OP
Ya, the hanger is just about flush. yes i ground down the body mounts. Probably bout 20min with cut-off disc and made it SO much easier to weld.
And that paint job unfortunately won't last a winter most likely. <img src="/forums/images/graemlins/angry.gif" alt="" />
-Scerb
Re: Scerb's SAS [Re: Scerb] #809223 05/29/07 01:07 AM
Scerb Offline OP
So I towed the truck back into my driveway with my 2wd. The SAS is mostly done (gotta brace the receiver tube/hanger a little bit since Ima be towing from it, weld in stocks/bumpstops, make driveshaft) but its driveable on the road right now. I replaced my timing chain, but in the process I was retarded and crunched the headgasket while putting the timing cover back in place. Serves me right for trying to rush it back together before work, I'm an idiot. So its head gasket time tomorrow <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Othern that, got some pics:
The two of them <img src="/forums/images/graemlins/lol.gif" alt="" />:
I got Tyler's old longfields <img src="/forums/images/graemlins/wink.gif" alt="" /> One birf turns real hard, and is covered under warranty. The splines on that same birf are pretty stripped. Bobby Long may replace the innards, or the whole birf, either way I got a good deal on about 1yr old longs. :
Gettin' there...
-Scerb
Re: Scerb's SAS [Re: Scerb] #809224 06/08/07 12:56 AM
Scerb Offline OP
So FINALLY it has been dry and daylight out when I have not been at work, and I got some pictars:
Got everything painted and the front has settled quite a bit which is good:
Flexed it out pretty good. The rear shock maxxed out - I gotta lessen the / \ angle of them.
I cheated and made an RTI ramp outa some 2x8's <img src="/forums/images/graemlins/baby.gif" alt="" /> (still only 2wd) :
I sorta eye-balled the bumpstops and it looks like I'm gonna need to only trim <1/2" off them, if that. Is that what other people have found with the TG 3" kit?
I also ordered a Marlin Crawler rotated dual case adapter today <img src="/forums/images/graemlins/smile.gif" alt="" /> After that and the Longfields go in, I'd say the truck is more/less happy for the next year or so.
-Scerb
Re: Scerb's SAS [Re: Scerb] #809225 06/08/07 09:05 AM
trcdrunner Offline
One more thing to add to your list of to do's.... <img src="/forums/images/graemlins/scared.gif" alt="" />
Paint the rear axle / springs too..... front looks nice & purty.. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
aka FireNIce
84 Runner 33" Swamper LTB, 4.30's, Spool in Rear, Lock-Right soon in front exo-caged, 4" lift.
TRCD Toys Web Site
TRCD Toys Apperal
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6444 MB (Peak: 0.7746 MB) Data Comp: Off Server Time: 2026-06-23 06:11:03 UTC
