bad idler arm #809590 05/03/07 09:45 PM
1
1986xtracab Offline OP
Drive back from fishing today I heard a noise coming from the front and adn when I got home I lifted the truck and checked it out, my Idler arm has play on both ends (where is connects to the sterring relay rod and the end that connects to the frame. I think I remember reading one here somewhere about being able to replace just the bushings on the idler arm, anyone remember that? have a link?
1986 xtra-cab 22re
stock everything
1991 bed
Re: bad idler arm [Re: 1986xtracab] #809591 05/03/07 09:50 PM
4Crawler Offline
Re: bad idler arm [Re: 4Crawler] #809592 05/03/07 11:00 PM
ErikB Offline
Toyota Moderator
The relay rod end isn't serviceable so you need to replace the arm.
I'd recommend replacing it with a Total Chaos idler which is fully rebuildable, but you will probably never need to.
http://www.4x4wire.com/forums/showflat.php?Cat=&Board=UBB11&Number=984760
http://home.4x4wire.com/erik
Re: bad idler arm [Re: ErikB] #809593 05/03/07 11:41 PM
1
yea I figured that part wasn't rebuildable, I'm putting all neew tie rod ends in soon anyways, so it's a good time to do it.
1986 xtra-cab 22re
stock everything
1991 bed
Re: bad idler arm [Re: 1986xtracab] #809594 05/04/07 11:45 AM
F
ffountain Offline
You may want to look back at my post on 4/28/07. It may be of help to you.
http://www.4x4wire.com/toyota/maintenance/idler/
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.011s) Memory: 0.6026 MB (Peak: 0.6670 MB) Data Comp: Off Server Time: 2026-11-05 18:28:24 UTC
