Re: Leaf Center Pins [Re: maxwell417] #809983 05/10/07 01:43 PM
Happy Birthday Richard Saylor Offline
I could've sworn Smiley's Rodeo is a 5 speed. <img src="/forums/images/graemlins/confused.gif" alt="" />
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: Leaf Center Pins [Re: Richard Saylor] #809984 05/10/07 02:51 PM
Smiley Offline
Ok so snapping a center pin isn't uncommon
True & True <img src="/forums/images/graemlins/wink.gif" alt="" />
<img src="/forums/images/graemlins/smile.gif" alt="" />
Six Isuzus, so far... still have three of them.
Re: Leaf Center Pins [Re: Smiley] #809985 05/10/07 02:56 PM
I thought so. Didn't think I was <img src="/forums/images/graemlins/drunk.gif" alt="" /> already. <img src="/forums/images/graemlins/notooth.gif" alt="" />
84 Honda XL185S
Re: Leaf Center Pins [Re: Richard Saylor] #809986 05/10/07 06:47 PM
lttlbddy Offline
Seriously, if you keep your u-bolts torqued good, you shouldn't break center pins. As for the rust, like I said, I coat them liberally with anti-sieze when I install, but then again, I don't drive through as much water as you guys.
Like a lot of things, with good maintenance, it shouldn't be a problem. That said, I carry extras too!!
Re: Leaf Center Pins [Re: Smiley] #809987 05/11/07 12:53 AM
maxwell417 Offline OP
I was joking <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/nana.gif" alt="" />
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
Re: Leaf Center Pins [Re: lttlbddy] #809988 05/13/07 07:15 PM
E
Eric Upchurch Offline
The DOR stuff did come with a replacement bolt. I usually use grade 8.8 hex head bolts to replace the center pins with. I also grease them liberally with antiseeze, this will stop the rust. Make sure your u-bolts are torqued to spec. Check them occasionally. If the u-bolts allow a little bit of movement, it will slowly grind through whatever you use as a center pin.
The socket headed cap screws (allen head bolts) are stronger than the 8.8, the 8.8 is metric and equivalent to a standard grade 5. (I work at Fastenal and sell bolts for a living..) The metric allen screws are a 12.9 grade equivalent to a standard grade 9. the standard SHCS (allen head bolts are an alloy = to a grade 9. If your looking for spares don't waste money on bolts that are labeled (center pin bolts) just go to your local fastenal or equivalent store (not trying to advertise) and get a box of 25 or 50(which ever comes in a box) 5/16 or 3/8 socket headed cap screws for about $15 and you'll have plenty for everyone. Hope this helps
Eric
New rig: 89 trooper RS toyota axles with 5.29s, 35x15.5x15 swamper SXs
my Pics: http://community.webshots.com/album/124372714fTyMKI
Wrire up:http://personal.ecu.edu/emu0416/
Re: Leaf Center Pins [Re: Eric Upchurch] #809989 05/13/07 07:27 PM
lttlbddy Offline
Socket headed cap screw is actually what I meant, bad terminology on my part. Thanks
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6285 MB (Peak: 0.7212 MB) Data Comp: Off Server Time: 2026-06-17 10:39:26 UTC
