Turnsignal won't cancel #810139 05/07/07 03:11 AM
BlueXJ Offline OP
I have an older XJ (90) and my L turn signal cancels just fine on its own but the R one has to be cancelled manually.
Anyone know how to fix this and before someone says it I will say I searched before posting this question.
I don't want to look like an eighty year old with my turn signal on for a hundred miles so help me fix this.
90 XJ 4.0L 3.5RE on 31s 242 SYE 12K MM winch
Re: Turnsignal won't cancel [Re: BlueXJ] #810140 05/07/07 03:42 AM
BigJim Offline
I think the repair is on the front side bottom of the steering column. An adjustment may be all you need to do.
Re: Turnsignal won't cancel [Re: BlueXJ] #810141 05/07/07 05:18 AM
BobRowe Offline
On my old CJ, a problem such as you describe would reqire changing the turn signal switch inside the top of the steering column. If fact, I have done it twice.
Unfortunately, I have no experience with XJ's, so I don't know how yours is set up.
Have you purchased an aftermarket repair manual for your model?
Re: Turnsignal won't cancel [Re: BobRowe] #810142 05/07/07 05:29 AM
BlueXJ Offline OP
Yes I have but that seems vto have been missed.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5997 MB (Peak: 0.6550 MB) Data Comp: Off Server Time: 2026-10-22 06:57:01 UTC
