Page 2 of 10 1 2 3 4 9 10
Re: My "Budget" Build Thread [Re: 4xToy] #810158 05/14/07 02:21 PM
W
warpig Offline
That's the plan, now if I can just find one. I'm just trying to find parts that are as compact (and inexpensive)as possible. This isn't going to be a hardcore rig, but I do want it to be reliable, since I will be hauling my family around in it. Have you settled on a tranny/t-case yet? I had thought about a Dana 300/Turbo 350, but the adapters are a $$$$ KILLER.
Re: My "Budget" Build Thread [Re: warpig] #810159 05/14/07 02:52 PM
Starchild Offline
Check this thread out T-case adapters
I used a stock NP208 adapter going from my 700R4 to Dana 300. It sounds like it should be the same setup for a 350. Much cheaper way to go. Just need a new input shaft for the 300.
HIH,
<img src="/forums/images/graemlins/cheers.gif" alt="" />Andre
"SERENITY NOW!"
Re: My "Budget" Build Thread [Re: Starchild] #810160 05/19/07 02:12 AM
4xToy Offline OP
Started cutting <img src="/forums/images/graemlins/shiner.gif" alt="" /> There ain't no going back now! I still have alot of clean up to do as everyone who has done a sas knows. What is the best way to cut off those cast idler arm brackets? I've tried burning out the welds but not much luck.
I am going to my uncles tomorrow to pick up my Chevy Dana 44 axle and look at a possible ford 9" for the rear.
I plan on building a jig to narrow and rotate the knuckles to match a waggy drivers side axle shaft. Can someone with a waggy axle measure the drivers side tube for me? I need it from the edge of the cast diff housing to some good reference point on the other end. I am trying to figure out if I just narrow one side, will I be wider than a waggy dif.
Oh, I need a Driver side waggy shaft and a passenger side inner Chevy shaft if anyone has some lying around.
-Chad
Re: My "Budget" Build Thread [Re: 4xToy] #810161 05/19/07 05:56 AM
lttlbddy Offline
A bunch of cutoff wheels and an angle grinder will get the big chunks off. Then smooth it out with a grinder wheel.
Re: My "Budget" Build Thread [Re: lttlbddy] #810162 05/19/07 10:06 PM
4xToy Offline OP
Picked up some parts today. The dana axle needes a drverside inner shaft but I picked it up for $100 and The Ford 9" was Free! I Thought it was an 8" at first but I verified it was indeed a 9". I'm going to pull the axles and see what spline count it has. It is out of a car so my width is just right to match a 63" front axle. I will need to buy new blank shafts for it so I can make it 6lug. Or I may just sell it, not sure yet. The tires are on loan so I can use them to set up my height. But I'll probably buy them later if I can find 1 or 2 matching 35" TSL radials since there is only three good ones. They also came with some aluminum Modular wheels that I also need to find one match for.
-Chad
Re: My "Budget" Build Thread [Re: 4xToy] #810163 05/25/07 11:57 PM
4xToy Offline OP
Just a quick update. I've been doing the dreaded grinding which sucks with my mild case of ADD <img src="/forums/images/graemlins/scared.gif" alt="" /> I grid a little then find something else to do for a while...you know. Anyway I found a '94 Blazer 4x4 with vortec 4.3 I'm picking it up tomorrow. I'm gonna just scrap the truck after I get what I want off of it. I found out today that to get the 61.5" waggy length out of my Chevy axle I need to cut and shorten both sides of the axle, which is ok because I will be rotating my knucles anyway. I'll try and get some pics for the long weekend <img src="/forums/images/graemlins/cheers.gif" alt="" />
-Chad
Re: My "Budget" Build Thread [Re: 4xToy] #810164 05/26/07 03:46 AM
strawmyers Offline
Isuzu Moderator
THIS is a great page for any D44 questions you may have.
Sean Strawmyer
Re: My "Budget" Build Thread [Re: strawmyers] #810165 05/27/07 08:05 PM
CPOM Offline
Take a wire brush on your grinder and clean up around the brackets. Often times the bracket is only welded on in a few inches -- if you hit that with the torch or disc the bracket falls off with a sledge.
CHRIS
98 Amigo, 92 Pup
Re: My "Budget" Build Thread [Re: CPOM] #810166 05/28/07 02:02 PM
4xToy Offline OP
Got my donor vhicle Saturday $375. It is a 1994 4.3 vortec with a 4x4 4l60. Pulled the motor and harness yesterday. Before anyone says anything, I'm not using that t-case <img src="/forums/images/graemlins/nana.gif" alt="" /> Now I've got to get that eye sore of a Blazer out of my driveway. And clean up that mess. It is driving me insane! I've already spilled 2qts of oil on a drive that is only 5 weeks old <img src="/forums/images/graemlins/zombie.gif" alt="" />. Well it was bound to happen eventually. Lucklly all of the mess is behind a big gate so only I have to look at it.
-Chad
Re: My "Budget" Build Thread [Re: 4xToy] #810167 05/28/07 02:18 PM
4xToy Offline OP
Oh yeah, I have a bit of useful info for those would are planning a dana 44 swap....
Axle shaft dimensions:
Wagoneer front dana44 WMS-WMS Roughly 61.5"
Waggy inner axle shaft lenghts:
Passenger inner shaft =14.69" 30 spline
Drivers inner shaft =33.19" 30 spline
Chevy Blazer Dana44 irregular cover (Don't know what that means but it seems to be the standard on these trucks) WMS-WMS Roughly 67.5"
Chevy axle shaft lenghts:
Passenger inner shaft =18.31 30 spline
Drivers inner shaft =36.13 30 spline
All outer shafts are 9.94" 19 spline on chevys and waggys
Doing the math, I'm 1/2" off some where, and I'm sure it is my measurement of the Chevy WMS's or the waggy WMS's I picked up on the fourm. All axle shaft lenghts were obtained from Warn industries website.
This ultimately means to me that I will be shortening both sides of my axle to get the desired lenght.
-Chad
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.007s) Memory: 0.6461 MB (Peak: 0.7568 MB) Data Comp: Off Server Time: 2026-06-10 06:26:06 UTC
