Rear axle seals
#810461
05/08/07 10:16 PM
I seem to be doing these every year. Maybe IÆm damaging them or not installing them correctly (crooked, not properly seated etc)
How can I make sure to do the job RIGHT?
Use a seal driver? How far do I drive the seal in? Extra careful when re-installing the axle?
Any hints and tips are extremely appreciated. IÆm going to be replacing the rear wheel bearings as they are growling at me (can a bad bearing be causing the latest leak, or is it likely the leak washed out the bearing causing it to go bad? Chicken or the egg?)
The only thing I'm pretty sure I'm doing correctly is greasing the rubber part of the seal before installation.
Thanks!
1988 4Runner, V6 Auto, Mostly Stock 32 x 9.5 Swampers
Re: Rear axle seals
[Re: The_Rusty_Gear]
#810462
05/08/07 10:23 PM
Toyota Moderator
Yes, a bad bearing can cause a leak and yes a leaky seal can also wash out the grease in the bearing since the oil has to leak through the bearing to get to and past the outer seal.
If/when you get an oil leak, I'd recommend using a needle attachement on your grease gun, sliding it under the bearing seal lip and filling the bearing back up with grease when you replace the seal. Might be a good idea any time you have your shafts out for that matter (while swapping a 3rd, etc.).
Re: Rear axle seals
[Re: ErikB]
#810463
05/08/07 10:26 PM
That's a great idea with the needle attachment.
Marlin has some new axle seals with a lip that supposedly helps get them in there straight.
83 4x4, 3" Lift, 33" Buckshot Mudders
Re: Rear axle seals
[Re: coryc85]
#810464
05/09/07 02:10 AM
is the breather on your axel working properly? or is it clogged. If it is clogged it could be building up to much pressure and blowing out thre seals.
1986 xtra-cab 22re stock everything 1991 bed
Re: Rear axle seals
[Re: 1986xtracab]
#810465
05/09/07 04:06 AM
x 2 on check the braether.mine was stopped up causing pres to build up when it got hot and push oil out the seal.I replaced the stock breather with one off an old pathfinder and added enough hose to get the outlet out of harms way.make sure there are no low spots in the hose to trap moisture
oh what a feeling: #1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered #2 86 sr5 4x4 efi parts truck #3 87 2wd parts truck 84 supra yard art
Re: Rear axle seals
#810466
05/09/07 04:40 AM
I now have to think that your truck is cursed Mike and suggest an exorcism or replacement with a JDM 80 series...
Re: Rear axle seals
[Re: cktoy]
#810467
05/09/07 03:00 PM
x 2 on check the braether.mine was stopped up causing pres to build up when it got hot and push oil out the seal.I replaced the stock breather with one off an old pathfinder and added enough hose to get the outlet out of harms way.make sure there are no low spots in the hose to trap moisture Extended breathers working fine with no low spots. Thanks for the input!
Re: Rear axle seals
[Re: jasonmt]
#810468
05/09/07 03:06 PM
I now have to think that your truck is cursed Mike and suggest an exorcism or replacement with a JDM 80 series... I think it's been cursed for awhile. I blame all of the previous four owners of the truck  And don't you be tempting me with a sweet sweet JDM 80! I couldn't handle the happiness!
Re: Rear axle seals
#810469
05/09/07 09:03 PM
Besides all the other suggestions,a bent housing can cause a leak, a bent axle shaft can cause a leak.
"Serenity through Sobriety"
