89 YJ Started back firing #810788 05/09/07 06:15 PM
RLBomber Offline OP
I haven't had a problem in almost a year (knock on wood), but now the jeep is back firing when slowing down. I let off the gas and use the engine to slow and it will back fire a few times and it never did this before.
4.2 / manual has new plugs and wires, cap and rotor. It does have an after market Howell TBI as well.
My first thoughts is that I have a leaky exhaust and will be checking that out. But wouldn't the timing if off cause this as well?
Re: 89 YJ Started back firing [Re: RLBomber] #810789 05/09/07 06:21 PM
Brown81CJ5 Offline
You can start by checking the timing. If that does not solve the problem then check cylinder compression.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: 89 YJ Started back firing [Re: Brown81CJ5] #810790 05/09/07 08:56 PM
BigJim Offline
Backfiring in the muffler/tail pipe is sometimes a result of unburnt gas making it's way to a hot spot in the pipes and igniting there. (sometimes)
If you are changing gears to slow the vehicle...1/4 ton vehicles have enough brakes to do the job...braking with the gears is not required.
But you could have a leak in the manifold or pipe that is sucking air in there too.
Re: 89 YJ Started back firing [Re: BigJim] #810791 05/10/07 03:53 PM
RLBomber Offline OP
Well, it turns out to be the exhaust pipe, found the hole.
Anyway, thank you for your input.
rlbomber
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5997 MB (Peak: 0.6555 MB) Data Comp: Off Server Time: 2026-06-15 10:09:59 UTC
