Page 2 of 3 1 2 3
Re: When I remove my doors, how do I get the dome lights to stay off? [Re: DBL_DTY97TJ] #810808 05/16/07 03:32 AM
fishtaker Offline
Yep. The fuse disables the door switch only. I don't know how it works, but Friday night I was fishin with a friend and his YJ. We were talkin about the door switch and I pulled it and showed him.
03 TJ 5 Speed I-6 30X9.50 BFG KO's
Re: When I remove my doors, how do I get the dome lights to stay off? [Re: fishtaker] #810809 05/17/07 02:00 PM
DBL_DTY97TJ Offline
I'll have to give that a try....
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: When I remove my doors, how do I get the dome lights to stay off? [Re: linworthas] #810810 05/18/07 02:33 AM
bradford_johnson Offline
Check out the TJ Dome Light switch available on Quadratec. Here is a link http://www.quadratec.com/products/13029_200.htm
I've purchased one and the installation looks easy. Waiting for the weather before I tackle it.
2004 TJ Wrangler Sport
Re: When I remove my doors, how do I get the dome lights to stay off? [Re: linworthas] #810811 05/18/07 03:12 AM
playinmud Offline
pull the #4 fuse, the dome lights will still come on when you manually turn them on, but beware, when the #4 fuse is pulled it also disables the audible tone you get when you leave your lights on and the car is shut off, just remember that when your doors are off always check to make sure your lights are off every time you shut the car off, ive done it some many times ive found that even in the middle of day when its sunny as could be i still check to make sure the lights are off
WHEN THE ROAD ENDS, THE FUN BEGINS
97 sahara, 4in skyjacker lift, 33in tires, borla header & catback, 10in subs
Re: When I remove my doors, how do I get the dome lights to stay off? [Re: playinmud] #810812 05/18/07 04:20 AM
BobRowe Offline
Gee, what did we ever do before they put those warning tones in the cars? <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: When I remove my doors, how do I get the dome lights to stay off? [Re: BobRowe] #810813 05/18/07 04:15 PM
Chris72 Offline
Dome light? Heck, in my Jeep, my dome light was the 2D Maglite I kept next to the seat <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: When I remove my doors, how do I get the dome lights to stay off? [Re: fishtaker] #810814 05/22/07 01:33 PM
DBL_DTY97TJ Offline
Well I just tested that out last night and it worked! I'm a bit surprised that the light is double sourced from two different circuits. Is this common in the automotive industry? I'm more familiar with building wiring....that would be really dangerous. <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: When I remove my doors, how do I get the dome lights to stay off? [Re: DBL_DTY97TJ] #810815 05/22/07 02:55 PM
BobRowe Offline
A lot of dome lights in vehicles have constant 12volt power on one side of the lamp, and the lamp is turned on and off by applying and removing the ground on the other side of the lamp. Could that be what's happening here?
Re: When I remove my doors, how do I get the dome lights to stay off? [Re: BobRowe] #810816 05/22/07 04:04 PM
DBL_DTY97TJ Offline
Could be....Door switches work off fuse No. 4 and the headlamp/dome light switch could be on the ground side. Just speculating though....
Re: When I remove my doors, how do I get the dome lights to stay off? [Re: DBL_DTY97TJ] #810817 05/22/07 08:51 PM
Baldy Offline
Take the bulb out.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6380 MB (Peak: 0.7442 MB) Data Comp: Off Server Time: 2026-07-13 11:48:16 UTC
