Lift #810836 05/09/07 10:50 PM
kornblind9 Offline OP
I have a '98 Jeep with a 3" suspension and 1" inch body lift on it. I was looking into getting a bigger lift all together. I was looking at a 8" Skyjacker lift. I was wondering if i would have to alter my drivetrain or make any adjustments to my engine if i lift it this high. Thanks.
'98 TJ, Manual, 3" Susp and 1" Body lifts, 33" BfGoodrich Mud Terrains, Winch, JET Stage 1/2 Power Module Computer Chip
Re: Lift [Re: kornblind9] #810837 05/10/07 07:09 AM
BobRowe Offline
Which model of '98 Jeep do you have, and what size tires are you planning on putting on it?
Re: Lift [Re: BobRowe] #810838 05/10/07 02:11 PM
CoronaJeeper Offline
If you have a body lift, you must have a TJ. Having said that, if you are going for 8" of lift, This would be my suggestion:
Remove the 1" pucks, and install a 2" or 3" body lift.
Install a good 4" suspension lift.
Add 2" spring spacers on top of that. (the alternative to this setup would be an ultra-pricey long arm 6" system)
You will of course have to add a slip-yoke eliminator to the t-case, as well as a new rear drive shaft. Something will have to be done about the severe angle of the steering components. Maybe a high-steer conversion, along with a dropped pitman arm (which should have come with the 4" kit).
And don't forget regearing axles for the larger tires. The rear Dana 35 will not survive, and will have to swapped out.
As you are probably figuring out, this is a expensive and labor-intensive operation you are looking at. Costs for this type of mod go up exponentially at these lift heights.
Why so high? What size tires are you planning to run?
Your finished product is going to be a fairly unfriendly beast to drive on the street, as you probably know.
Not trying to discourage you, just being honest.
Corona <img src="/forums/images/graemlins/cheers.gif" alt="" />
'98 TJ, 4 cyl., auto
31" AT KO's on rockcrawlers,
custom bumpers, Hellas
2" Teraflex lift, no top,
no doors, no problem.
Re: Lift [Re: CoronaJeeper] #810839 05/10/07 04:12 PM
Brown81CJ5 Offline
I would get rid of the body lift all together and get an 8 inch long arm kit. Fabtech and SkyJacker both have 8 inch kits. SkyJacker even has a 10 inch kit.
I am also curious about what size tires you will be running, and what type of wheeling you will be doing.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: Lift [Re: Brown81CJ5] #810840 05/10/07 04:49 PM
DBL_DTY97TJ Offline
I'd go with 8 or 10 inch long arm kit too, plus the drive train mods. I would never do a 3" body lift again...too many issues appear later even when shifters etc. have been re-set up well.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: Lift [Re: DBL_DTY97TJ] #810841 05/10/07 07:38 PM
I would just like to say, that if given a choice, I'd never do a body lift, but this guy wants 8" of lift, <img src="/forums/images/graemlins/zombie.gif" alt="" />and I was trying to give him an idea of how to do it halfway affordably. Has anyone here priced an 8" longarm kit? Holy schnikees, they're pricey. <img src="/forums/images/graemlins/barf.gif" alt="" /> That's all I'm sayin'... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Corona
Re: Lift [Re: CoronaJeeper] #810842 05/10/07 09:41 PM
Alright..Yea i know an 8" lift wont be a cheap purchase and there is a possibility ill just stick wiht my 4" lift. I was just checking out the alterations I would have to make.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6113 MB (Peak: 0.7056 MB) Data Comp: Off Server Time: 2026-07-13 22:17:03 UTC
