Hy steer on a 85 4runner? #810922 05/10/07 05:13 AM
4
4x4yotaman Offline OP
I am going to be putting high steer on my 85 4runner this weekend and i was wondering what kind of troubles i might run into. I have an ifs steering box and a ifs steering box mount from marlin. I want to know if the 85 steering shaft will reach and fit and if the 85 power steering lines will work with the ifs box. Also the front suspesion is being lifted 3 inches is that enough lift for the hysteer setup to work properly?
1985 4runner
Re: Hy steer on a 85 4runner? [Re: 4x4yotaman] #810923 05/10/07 05:16 AM
4Crawler Offline
Yes, yes and just barely.
For steering shaft, see:
- http://www.4crawler.com/4x4/ForSale/Docs/BodyLift_HowTo.shtml#RecirculatingBall
http://www.4crawler.com/4x4/CheapTricks/CrossoverSteering/index.shtml
Re: Hy steer on a 85 4runner? [Re: 4Crawler] #810924 05/10/07 05:38 AM
4
thanks i should have known to check your site
1985 4runner
Re: Hy steer on a 85 4runner? [Re: 4x4yotaman] #810925 05/10/07 12:42 PM
missouriman Offline
I have 3 inch lift and just had to lower the bump stops a bit.
pictures here.
web page
Re: Hy steer on a 85 4runner? [Re: missouriman] #810926 05/10/07 04:05 PM
bkg Offline
move the box as far forward as you possibly can, then tilt it upward as far as possible if using a "stock" type pitman arm. The trick to doing this w/ low lift is to get the end of the pitman arm as close to the frame as possible. Good friend actually had Marlin create a pitman arm w/ reverse taper for his 85 w/ 2" lift.
Brian K. Gallus
Re: Hy steer on a 85 4runner? [Re: bkg] #810927 05/10/07 08:43 PM
Staceman Offline
X2
Otherwise, as you stuff your front left tire into the fender, your leaf spring will get "caught" with the pitman nut, and you won't be able to steer at all. Don't ask me how I know. <img src="/forums/images/graemlins/drunk.gif" alt="" />
Re: Hy steer on a 85 4runner? [Re: Staceman] #810928 05/11/07 12:03 AM
Dingman Offline
x3 , been there, done that
X2
Paved Roads ~ Another example of wasteful government spending.
'85 $runner, lifted and locked.
See the Ding_yota here
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6207 MB (Peak: 0.7117 MB) Data Comp: Off Server Time: 2026-05-29 17:13:38 UTC
