Rough Country 6" lift for YJ #810941 05/10/07 06:14 AM
hoki06 Offline OP
Hey I am wondering what the general review on this 6" lift for YJs. I've looked at the 4.5" Rubicon Express lift and it looks pretty good but so does the 6" RC. Let me know if you guys have any info on the Rough Country lift and how it performs. Thanks
Re: Rough Country 6" lift for YJ [Re: hoki06] #810942 05/10/07 07:14 AM
BobRowe Offline
As a general rule, for leaf-spring-suspended Jeeps, the higher the lift, the more problems you are likely to run into, such as steering, driveline angles, etc. So you will likely run into more of these problems with a 6" lift than with a 4.5" lift.
What size tires are you planning on running on your YJ?
Re: Rough Country 6" lift for YJ [Re: BobRowe] #810943 05/10/07 12:27 PM
hoki06 Offline OP
Either 33" or 35" I haven't really decided. I would like 35s because they are bigger but it may be less of a headache to do 33s
Re: Rough Country 6" lift for YJ [Re: hoki06] #810944 05/10/07 04:31 PM
Brown81CJ5 Offline
The RE 4.5" will clear room for 33x12.50's. A 1"-2" body lift with that should clear 35's.
The only thing I've heard about Rough Country is just that...rough.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: Rough Country 6" lift for YJ [Re: Brown81CJ5] #810945 05/11/07 01:00 AM
hoki06 Offline OP
well its a father-son project and i think my dad is more concerned about price and looks not performance so i may end up going with the rough country 4" and a body lift with 33 bfg at's
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6029 MB (Peak: 0.6667 MB) Data Comp: Off Server Time: 2026-06-21 22:39:16 UTC
