trying to converting a two wheel drive tranny #811119 05/10/07 10:35 PM
juks Offline OP
i have what i think is a sm465 4 gear out of a 76' camper special. i have it in my mud truck now but i am having a hard time finding a np 205 case that will bolt up to it. i thought i counted 35 splines on the output shaft and the case i have now only has 28 (i think) i am new to chevy stuff so can anyone tell me what adaptor and t-case i need to complete this swap. any advise is very much apreciated!!
Re: trying to converting a two wheel drive tranny [Re: juks] #811120 10/08/07 12:30 AM
mechanic58 Offline
You will need to totally disassemble your SM465 and swap out the output shaft. An SM465 for a 4WD application will use a 10 spline output which is shorter than the 2wd shaft and will mate to a 10 spline input NP205 with the appropriate adapter. (These parts should all be available from a junkyard) You can NOT use your existing output shaft. Check ebay.
2007 Ford F150 Supercab
PHP: 7.4.33 Page Time: 2.569s Queries: 15 (0.003s) Memory: 0.5876 MB (Peak: 0.6351 MB) Data Comp: Off Server Time: 2026-06-07 09:04:26 UTC
