Page 2 of 3 1 2 3
Re: Sounds like there's a gnome with a hammer under my Gen2 [Re: generation_one] #811167 05/12/07 01:11 AM
nedfunnell Offline OP
Just took a look underneath.
Any other ideas?
cv joint boot
Ewww. I hope it's not that. Good idea, though- thanks.
95 Montero SR - 207k miles, rebuilt @ 146k
Stock. Longview, Texas
Ithaca, NY for the summer of 08.
Re: Sounds like there's a gnome with a hammer under my Gen2 [Re: nedfunnell] #811168 05/12/07 03:14 AM
sparkem Offline
A worn out broken CV can rattle around some too. Grab the shaft of the CVs and shake around.
Or put a giant mouse trap with Gnome food as bait.
Re: Sounds like there's a gnome with a hammer under my Gen2 [Re: nedfunnell] #811169 05/12/07 03:56 AM
Oyaji_Jon Offline
Any other ideas?
cv joint boot
CV joint shouldn't make a rattling noise while driving on the road...
...unless, of course you are driving around in 4wd all the time <img src="/forums/images/graemlins/shame.gif" alt="" />
The point is, it won't click unless it's turning and it won't turn unless it's in 4wd...
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Sounds like there's a gnome with a hammer under my Gen2 [Re: Oyaji_Jon] #811170 05/12/07 04:04 AM
stony-man Offline
I blew one, and it made a lot of racket when in 2wd. But it was pretty consistent, didn't come and go too much. But it was worse in turns. It did sound like someone with a hammer was banging on the axle though. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Sounds like there's a gnome with a hammer under my Gen2 [Re: Oyaji_Jon] #811171 05/12/07 04:05 AM
4WD can't engage unless the lever is in position, right? I keep the lever in 2Hi(Edit- originally said 4Hi- typo), but sometimes I'm suspicious of it staying in 4WD because the lights take forever to go out, usually(when transferring when stopped, in N) I have to put it in drive and roll forward a few inches before it will disengage. The center diff and rear diffs both take a long, long time to disengage too. Is this normal?
Re: Sounds like there's a gnome with a hammer under my Gen2 [Re: stony-man] #811172 05/12/07 05:02 AM
Oyaji_Jon Offline
It makes no sense to me that an axle can make noise when it's not turning. Does the Gen II have disconnecting hubs? On the wife's Rodeo, the front has drive flanges which make the CVs constantly engaged turning the front diff and axles all the time. The t-case is the single disconnect point. Do the later Monties work the same way? That is the only way I can think that the front CVs would be affected in 2wd.
As far as driving around in 4 HI all the time, I don't understand why you'd do that. If you ARE driving that way, then there are a few things in the front driveline that could be making noise and the driveshafts are one of them.
Once again, go get a look...
73
-Jon
KJ6GVM
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Sounds like there's a gnome with a hammer under my Gen2 [Re: Oyaji_Jon] #811173 05/12/07 05:39 AM
D'oh! I meant to say 2Hi. I'll go back and edit my post.
I'll check out the CV joint, too.
Re: Sounds like there's a gnome with a hammer under my Gen2 [Re: Oyaji_Jon] #811174 05/12/07 05:43 AM
justice Offline
On gen II's the CV's are always turning unless you fit aftermarket manual hubs. So if you had a bad CV this may cause a clicking sound. Driving around on pavement in 4hi is Fine it just like what most would call AWD (center diff unlocked). (just dont drive around pavement in High or low Lock) Anyways its perfectly normal for the flashing lights it takes a while to disengage. If you use the 4hi(active track) a lot maybe you wore out the CV. I would advise to drive in 2wd whenever on the hardball and I fitted manual hubs to reduce wear on the CV's and boots. Also driving in 4 hi will killyour gas milage but its great for wet or slippery conditions.
Re: Sounds like there's a gnome with a hammer under my Gen2 [Re: justice] #811175 05/12/07 07:16 AM
Oyaji_Jon Offline
That's what I wanted to know. The system is similar to my wife's Rodeo, then. Our Rodeo doesn't have the diff lock, though. Anyway, I understand the desire for 4 hi in slick conditions, but can't driving in 4wd at high rates of speed/all times damage the system? At the least it HAS to be rough on the tires, right? I wouldn't run my trucks that way.
Back on topic, with the system working the way it does, I do agree that your CVs COULD be suspect. Gotta check it out, man...
73
-Jon
KJ6GVM
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Sounds like there's a gnome with a hammer under my Gen2 [Re: Oyaji_Jon] #811176 05/12/07 04:59 PM
sparkem Offline
I was saying a severly worn/broken CV can make noise when non turning. A perfect condition should not make any noise at all.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6441 MB (Peak: 0.7560 MB) Data Comp: Off Server Time: 2026-06-20 16:48:22 UTC
