Page 3 of 3 1 2 3
Re: I am in a debate.................. [Re: Everet] #811274 05/15/07 05:36 AM
Everet Offline
Iron, did you get the valves or see the head with the bent valves?
Didn't answer my question, he must be running for office... <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Everet <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: I am in a debate.................. [Re: Everet] #811275 05/15/07 07:09 AM
fokion Offline OP
thats more or less the info I got... the valves didnt bent because of a BROKEN timing belt but because of a LOOSE timeing belt...
Either way... the valves SOULD not tuch the pistons UNLESS the return springs are toooooooooo soft
OR
Kia in the proses changed the profile of the cams and make them go deeper
OR
KIA made the head gasket thiner...
Re: I am in a debate.................. [Re: Everet] #811276 05/15/07 01:36 PM
Iron Offline
No! And the valves were not bent, the rising piston on the compression stroke closed the vave before any damage was done, just some valve marks on the carbon build up on the piston top to indicate contact!
08' Jeep Wrangler
64' Plymouth Sport Fury 383
58' Triumph TR-3A
Re: I am in a debate.................. [Re: fokion] #811277 05/15/07 01:37 PM
Iron Offline
OR
OR
Intresting you mention the head gasket! The head gasket was changed 6 months before this all happened under warrenty due to a leak!
08' Jeep Wrangler
58' Triumph TR-3A
Re: I am in a debate.................. [Re: Iron] #811278 05/15/07 02:00 PM
Axe Man Offline
Kia Moderator Emeritus
Took her in because of a tapping sound from the engine. After a month of not being able to solve the problem, the dealer pulled the head. An intake valve was sticking open and making contact with the top of the piston, which promptly closed the valve!
No broken timming belt, No broken valves, No damaged piston. But the valves did make contact with the top of the pistion! Since the Sporty was a month out of warrenty and I know the service manager, Hell I shoot him on a reagular basis on the paintball field, why would he lie? I paid for 1/2 the cost of the parts and NO labour, Also had the timming belt changed at the same time and the head tested for cracks, had all the valve seats honed, A new set of lifters and hydralic adjusters, basically I had the top end rebuilt!
In theory the engine is a Non-interferance engine.
In theory the Titanic was unsinkable
In theory the Paris Hilton should go to jail
If a valve spring broke or the HLA collapsed the valve would extend further into the combustion chamber than normal. That would explain the contact with the piston. Sounds like that's what happen in your case.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: I am in a debate.................. [Re: Axe Man] #811279 05/15/07 02:23 PM
Everet Offline
Good idea Axe! Also, marks on the Carbon build up...not on the piston. Depending on the carbon thickness, a non-interference motor can become an interference motor.... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: I am in a debate.................. [Re: Everet] #811280 05/16/07 01:26 AM
DEFBOY35 Offline
a just seen a motor today from a 01 sporty and it definately did not live up to the non interferance claim when his timing belt snapped.
wow do i ever need to change my belt asap!
2000 SPORTY, DEF BOY customs, mmm....lockers, mmm... gears, mmm... double transfer case, mmm... stroker
http://www.cardomain.com/ride/2377991
Re: I am in a debate.................. [Re: Axe Man] #811281 05/16/07 07:44 AM
fokion Offline OP
Axeman!!!!!! brilliant answer asw always...
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6310 MB (Peak: 0.7309 MB) Data Comp: Off Server Time: 2026-06-17 13:43:57 UTC
