Re: high mileage oil, is it bogus?
[Re: BigJim]
#811782
05/18/07 01:27 AM
<img src="/forums/images/graemlins/lol.gif" alt="" /> Big Jim,your "tune" is changing! You lazy old fart, here's a fun article that addresses this issue fairly well. Enjoy!
am not a lubrication, filtering, chemical or mechanical engineer. I have a degree in engineering, but I studied electrical engineering. I now study physics. You may feel free to question my abilities to gather facts and draw conclusions in the area of oils and filters. In any case, this is a write up of what I learned in about 75 hours of research on this topic. My only interest is having my motorcycle run forever, never break, and be easy to maintain.
Why do we need oil? We put oil in our engines to serve several purposes. First, obviously, oil acts as a lubricant. If your engine is operating correctly, there is almost no metal to metal contact - everything is riding on a thin film of oil. However, oil has several other important jobs to do. Oil circulates throughout your engine, and cools parts that cannot get near a water jacket. For example, it's becoming common in sport bikes to spray oil on the underside of the piston to cool it. There are no water jackets at all in your transmission. Motorcycle transmissions are oil cooled.
Your piston rings do not do a perfect job of sealing. Some combustion by products will slip past the rings into the engine. This can be little particles of carbon. Remember, diamond is carbon that was combined under heat and pressure. These little carbon particles can be quite damaging to your engine. Another job of your oil is to hold these particles in suspension until the oil filter can grab them. Also, if your gasoline has sulpher in it (it does), this sulpher can react with water and oxygen to make sulphuric acid. This is some stuff that is seriously bad for your engine. Your oil has special ingredients in it called buffers to neutralize acids. Finally, your engine can get internal build ups of tars, waxes, and other gunk. Your oil has solvents to try to dissolve this stuff and get and keep your engine clean.
Where Oil Comes From Most of the bio-mass on earth is single cell plants and microscopic critters in the ocean. When these die, they sink to the bottom. Often they fall into a deep crevasse or trench, where they may become covered up by an underwater landslide. After a couple hundred million years of high pressure and no air, the critters get squished into oil. So, oil isn't really "dead dinosaurs," but Sinclair Oil stations just wouldn't be the same with a picture of algie on their sign. Today we like to find this stuff, pump it to the surface, and burn it.
The oil we pump to the surface is a mixture of gasoline, kerosene, light weight lubricating oil, motor oil, gear oil, tars, paraffins, waxes, asphalt, sand, dirt, organic stuff (called aromatics) and the occasional dead cockroach. We call this stuff crude oil, for reasons that I think are now self-explanitory. The oil companies have the singularly smelly job of separating the crude oil into its component parts. A hundred years ago we would just heat the stuff up in a complicated still, and catch stuff that boiled off at different temperatures. Fifty years ago we started processing the crude oil with clay and solvents to do a more precise job. Today, we use very complicated systems where we heat the crude oil to precise temperatures, put it under high pressure, and bubble hydrogen and other stuff through it. The idea of all this is to try to get pure chemicals out of this stuff that we just found laying around in the desert.
Most motor oil has a lot of different chemicals in it with very different properties. The temperature at which the oil will start burning, called the flash point, is determined by the chemicals that burn at the lowest temperature. The higher the flash point, the more stable the oil is at high temperatures, and the less oil your engine will burn. The pour point is the temperature at which the oil stops flowing like a liquid. The lower this number is, the better protected your engine is when it's cold. The thickness of the oil, that is the resistance the oil offers to motion, is called the viscosity. The viscosity depends on all of the various chemicals in the oil and how they react to each other and to heat. Importantly, as the oil heats up, it thins out, that is the viscosity goes down. The better the oil is at retaining its viscosity at high temperatures, the higher the viscosity index. All of these properties depend on all the chemicals in the oil. If you could get only one precise kind of molecule out of the raw oil, you could do a lot better than you can do with a mix.
Refining Oil The oil product you buy starts as a base oil. The base oil makes up about 85% of the oil you buy. The base oil can be refined from crude oil, chemically (synthetically) manufactured, or a blended combination.
Base oils that are refined from crude oil are colorless and pretty much odorless and are sold to the public as mineral oil. The crude oil is a combination of a lot of different chemicals, ranging from light gasoline types of fuels to waxes and tars. When you heat the crude oil, the gasoline and diesel oil boil off pretty early. Unfortunately, the mineral oil, paraffin, wax and tar molecules are all hooked up with each other, and it's not so easy to separate them from each other. Also, the crude oil contains the aforementioned aromatics, which are quite bad in your oil: they are very reactive, and when oxidized they cause all kinds of problems. Refining oil means trying to remove the bad stuff, while leaving the good stuff. The more bad stuff we remove, the better the oil works.
The simplest way to refine oil is to process it with a clay, a material a lot like kitty litter. The clay will soak up much of the aromatics and sulpher and nitrogen compounds. Then, you dilute the oil with solvent like MEK (Methyl-Ethyl-Keytone) and/or Toluene (that's the stuff in model airplane glue that's so popular with teenagers), and freeze the oil. The good stuff will mostly stay liquid, and the waxes will solidify and can then be filtered out. This clay-solvent refining process has been around since about 1930.
Oils refined with the clay-solvent process contain a fair amount of paraffin and wax. These molecules cause several problems in an engine: they sometimes fall out of solution, leading to buildups in your engine that must be cleaned out somehow. Also, as these molecules get hot they thin out quite a bit, much more than mineral oil, so they make the oil's high temperature performance rather poor. Finally, at low temperatures the waxes and paraffins thicken the oil so much that you really couldn't call it a lubricant. If you're curious about this, buy a cheap quart of straight 30wt oil and put it in your refrigerator or freezer over night. You'll be amazed at how thick it becomes. More than half the motor oil sold in N.America in 2004 is made from base oils refined with the clay- solvent process (I like to call it the Kitty-litter and Kerosene refining method), but I don't think this is the type of oil you want to put into an engine you love. These oils are roughly 85% good stuff (oil) and 15% bad stuff (paraffin and wax). To put this in perspective, think of taking a gallon of really excellent oil, and melting a 12" dinner candle into it.
In 1959, Chevron developed a new method of refining base oils called Hydrocracking, where you process the raw oil at high temperatures and pressures with hydrogen and various catalysts. In Hydrocracking, many of the paraffin and wax molecules are broken up into mineral oil molecules, which increases the performance of the base oil dramatically. Also, far more of the aromatics and sulpher and nitrogen compounds are removed from the oil.
Since 1990, Chevron's process has been improved. In 1993, Chevron invented the Hydro-Isomerization process, where wax and paraffin molecules are reshaped into useful lubricants instead of simply being broken up into smaller molecules. By increasing the severity of the hydrocracking process, increasing the temperature and pressure and processing time to process more and more of the unwanted wax and paraffin molecules, the oil's low and high temperature performance and resistance to oxidation can be improved to the point where the distinction between mineral oils and synthetics becomes blurred. Chevron now licenses this process, called Iso- DeWaxing. This process of oil refining is becoming more and more popular, and in 2004 accounts for almost half of all base oils. Iso- DeWaxing not only produces much higher-performance oil, but also allows you to start with lower quality crude oil, making us less dependent on the few countries that happen to produce the purest crude oils.
Group II and Group III oils Base oils made with the Iso-DeWaxing process are called Group II, and are significantly more pure and have higher performance than Group I base oils. Chevron Delo 400, Mobil Delvac 1300, and Shell Rotella are made from pure Group II oils. Motor oils made with Group-II base oils leave far fewer wax and tar deposits in your engine, and have much better low and high temperature performance than Group I oils. The resulting oils are roughly 97% good stuff (oil) and 3% bad stuff (paraffin and wax). We just cut that 12" dinner candle down to about 2¢".
The high and low temperature performance of oils are described by the Viscosity Index. The VI tells us how much the oil thins out as it gets hot. Oils with higher VIs maintain their viscosity better at high temperatures. If the VI is 90 to 100, we call it Group II; if it's refined to a VI of 110 to 115 we call it Group IIa. In the late '90s, an even more involved process was invented yielding base oils with VIs over 120. These base oils are called Group III or "unconventional base oils." The higher the VI, the fewer additives are necessary to achieve the required viscosity. For example fewer additives are needed to turn a Group III base oil into 10w-40 than are required for Group II base oils. Group III oils have essentially no paraffin and wax in them, at least as compared to the 12" dinner candle per gallon in Group I oils.
Group III oils have properties approaching or equaling synthetics, so long as the temperature is above about 40?. Group III based oils are often claimed to not perform as well as synthetics in a couple ways: their low temperature performance is not nearly as good, it is sometimes claimed on the basis of the "ball bearing test" that they offer lower impact resistance, and since their flash point is slightly lower it is claimed that they burn off more easily. However, most modern engines are water-cooled, so it's hard to see how the slightly better flash points of the synthetics ever come into play. I personally don't make a habit of dropping a handful of ball bearing into my oil pan, so I'm not completely clear on what the impact tests mean to me. The low temperature performance of the Group III oils can be improved enormously by blending in a relatively small amount of synthetic base stock and other additives.
Since about 2000, it has become possible at moderate extra cost to process Group II and Group III oils so that their performance below 32? nearly matches the performance of traditional synthetics. Because of this, the oil companies found they could now produce relatively inexpensive 5w-30 and 0w-20 oils. Car companies were quick to see that such oils would help reduce the fuel consumption of their vehicles by a percent or so, which is important as Detroit finds themselves selling more trucks than cars. So, these "fuel-efficient" oils are quickly becoming the factory recommendation in most cars. It's not at all clear that these new low- viscosity oils lead to the longest engine life, but it is clear that these oils help the car companies meet their CAFE federally- mandated fuel economy standards.
In the late 1990s, Castrol started selling an oil made from Group III base oil and called it SynTec Full Synthetic. Mobil sued Castrol, asserting that this oil was not synthetic, but simply a highly refined petroleum oil, and therefore it was false advertising to call it synthetic. In 1999, Mobil lost their lawsuit. It was decided that the word "synthetic" was a marketing term and referred to properties, not to production methods or ingredients. Castrol continues to make SynTec out of Group III base oils, that is highly purified mineral oil with most all of the cockroach bits removed.
Shortly after Mobil lost their lawsuit, most oil companies started reformulating their synthetic oils to use Group III base stocks instead of PAOs or diester stocks as their primary component. Most of the "synthetic oil" you can buy today is actually mostly made of this highly-distilled and purified dino-juice called Group III oil. Group III base oils cost about half as much as the synthetics. By using a blend of mostly Group III oils and a smaller amount of "true" synthetics, the oil companies can produce a product that has nearly the same properties as the "true" synthetics, and nearly the same cost as the Group III oil. The much more expensive traditional synthetics are now available in their pure forms only in more expensive and harder to obtain oils. To the best of my knowledge, Delvac-1, AMSOil, Redline, and Motul 5100 are the only oils made from pure traditional synthetics.
Synthetic Oils Synthetic oils were originally designed for the purpose of having a very pure base oil with excellent properties. By starting from scratch and building up your oil molecules from little pieces, you can pretty much guarantee that every molecule in the oil is just like every other molecule, and therefore the properties are exactly what you designed in, not compromised by impurities from dead cockroach shells or whatever. Synthetics were thus originally a reaction to the relatively poor refining processes available from about 1930 to about 1990. The original synthetics were designed for the Army Air Force in WW II. They simply could not make their high- performance turbo-charged radial engines stay alive on the available motor oils of the time.
One process for making synthetic base oils is to start with a chemical called an olefin, and make new molecules by attaching them to each other in long chains, hence "poly." The primary advantage of Poly-Alpha-Olefin "PAO" base oil is that all the molecules in the base oil are pretty much identical, so it's easy to get the base oil to behave exactly as you like. PAOs are called Group IV base oils.
Until about 2000, these PAO base oils had an enormous advantage over mineral base oils in low temperature performance and in resistance to oxidation, which is critical in keeping the oil from forming acids. However, modern group-III oils can nearly match the performance of PAOs at about half the price. Because of this, PAO based oils are rapidly disappearing. There are new processes being investigated which may significantly cut the cost of producing PAOs, and make them an important component of oil again.
Another type of base oil is made from refined and processed esters and is called Group V. Esters start life as fatty acids in plants and animals, which are then chemically combined into esters, diesters, and polyesters. Your vegetarian girlfriend should love that. Group V base stocks are the most expensive of all to produce. However, the esters are polar molecules and have very significant solvent properties - an ester base oil all by itself will do a very decent job of keeping your engine clean. So, people who are serious about making a superior oil will usually mix some Group V oils into their base stock.
PolyEster (RedLine) oils have by far the best performance in extreme high temperatures, and are the preferred oil in old "air- cooled" Nortons. I put "air-cooled" in parenthesis as one could also call these engines "prayer- cooled." The Norton 750 commando will destroy a Group I oil fill in 75 miles on a 100 degree day. No kidding. The Brits really did not understand until about 1990 that some of us live in places where the temperatures get over 80 degrees and cities are more than 10 miles apart. If you love those old British twins, you need to find a good supply for RedLine oil.
Finally, there are new chemicals emerging which are made from liquefied natural gas called GTL (gas to liquid) base oils. These will be called Group III+, and many people think they will become an important part of the oils you buy by 2010. These GTL base oils have natural VIs of 140 or more, meaning for most applications they won't require any VII package at all. Natural gas is primarily made up of only one type of molecule, so the refining is already done for you. Most oil wells throw off a lot of natural gas. In many cases, it's more expensive to transport this gas to a large city than the gas is worth, so it's just burned off. For example, Iran burns off enough natural gas each day to power their entire country, electricity, cars, ships, airplanes, the whole thing. So the next time you hear Iran's nuclear reactors are purely for peaceful production of energy, you can wonder like the rest of us why a country that burns off more than their entire energy needs must spend tens of billions of dollars developing alternative energy sources. Well, anyway, natural gas is a chemical looking for a use. All you have to do is chemically attach these molecules to each other to turn them into quite pure oil stocks.
"Semi-synthetics" are oils which are a blend of petroleum oil and no more than 30% synthetic oil. If the manufacturer adds no more than 30% synthetic oil and does not change the additive package, they do not have to recertify the oil. These days, since everyone has agreed that Group III base oils are "synthetic," I'm not sure "semi-synthetic" means anything at all. The manufacturers love this stuff: it costs about 15% more to make the oil, and they get to charge about double. I don't recommend semi-synthetics. Save your money and take your kids to McDonalds.
Group I Mineral Oils Group II Mineral Oils Group III Mineral Oils Group IV PAOs Group V Diesters Base Oil Visc. Flash Point Pour Point VI Visc. Flash Point Pour Point VI Visc. Flash Point Pour Point VI Visc. Flash Point Pour Point VI Visc. Flash Point Pour Point VI 100 Neutral 4.1 380 +15?F 97 4.1 410 +20?F 102 4.2 410 +25?F 127 3.8 437 -92?F 123 3.6 460 -67?F 148 200 Neutral 6.1 420 +15?F 96 6.4 435 +25?F 103 7.0 460 +20?F 135 5.9 469 -83?F 135 5.5 485 -65?F 150 325 Neutral 8.4 435 +15?F 95 --- --- --- --- --- -- --- --- 8.4 507 -74?F 132 --- --- --- --- 450 Neutral 10. 455 +15?F 95 12. 500 +20?F 101 --- --- --- --- 9.5 527 -85?F 130 --- --- --- ---
As you can see in the table above, synthetics offer real advantages when your engine is very cold and when your engine is very hot. The viscosity numbers shown above are at 212?F. At 32?F the PAOs and Diesters have about one third the viscosity of the mineral oils, meaning they pump through your engine three times better. Since about 75% of all the wear on your engine happens in the first five minutes after you start it up, synthetics offer an advantage in significantly reducing engine wear.
Making Multi-Grade Oil A simple standard oil, for example a pure base stock, would be a single weight, like 30 weight. This pure oil would have no detergent additives to keep the engine clean. This oil would be relatively thick and difficult to pour at room temperature, and would thin out as the motor heated up. On a very cold day, say 10? below freezing, this oil would thicken to the point where you could not start your motor, and if you did, the oil pump could not pump the oil around to protect your motor. It used to be that to start their diesel trucks in the winter, truckers would add kerosene to their oil to thin it out. Then they had to hope the kerosene would burn off before it did any real damage. Today, synthetic oils that are rated 0W-40 flow normally down to 65? below zero and remove the need for engine block heaters or adding kerosene.
An oil sold as 10w-40 is no thicker than 10 weight oil under Winter (10w) conditions, meaning below freezing. The 40 means it is no thinner than 40 weight oil at 212? Fahrenheit. So, the first number tells us the performance of the oil at or below the temperature of freezing water, and the second number tells us the performance at the temperature of boiling water. The chemicals added to the oil to accomplish this are called Viscosity Index Improvers (VIIs).
To make a 10w-40 oil, the manufacturer would start out with a 10 weight oil as the base stock. All by itself, this oil would thin out so much at normal operating temperatures that the oil film would be useless. So, they add these very special very long molecules, the VIIs. The VII molecules are as much as 1000 times as long as an oil molecule. The VII molecules curl up in a little ball at room temperature, but as the temperature gets higher they uncurl and stretch out, like a cat sleeping in the sunlight. The more stretched out the molecule is, the more it impedes the normal flow of the oil, thus raising the effective viscosity. Now, this sounds just a little too good to be true. Well, there are two catches: first, these molecules are not lubricants, so the more of them that you add the less oil you have sitting around lubricating things. Secondly, these VII molecules can be broken into pieces by various pressures and forces, like being squeezed through the transmission gears in a motorcycle or the hydraulic valves in a diesel engine. Every time a VII molecule gets broken, the oil loses some of its high temperature viscosity. Synthetic oils made from pure PAOs and/or Diesters typically have very few VIIs, so these oils are far less subject to viscosity breakdown due to shearing of the VII package. As a result, synthetics are far more stable in a motorcycle engine.
10w-30 oil increases its viscosity at high temperatures by a factor of three, which requires a significant amount of these VII molecules. 10w-40 oil increases its high temperature viscosity by a factor of four, which requires even more even longer molecules. 20w-50, which sounds a lot like 10w-40, only increases its high temperature viscosity by a factor of two and a half, so it requires fewer of these molecules than even 10w-30. 15w-40 also increases its high temperature viscosity by about two and a half, so this oil is also substantially more stable than 10w-40. Most passenger car oils today use inexpensive VII molecules that break apart relatively easily. Conversely, most diesel engine oil VIIs are chosen from more expensive chemicals that are more shear stable, since an oil change in a large diesel is expected to last for 15,000 to 150,000 miles.
One way to judge the VII content of your oil is to read the VI, the Viscosity Index, at the manufacturer's web page. The base oils all have similar VIs to start with, so generally speaking, the higher the VI in the blended oil, the more VIIs are present, and the less suitable the oil is for motorcycle usage. John Evans did just such a survey of Valvoline, Chevron, Exxon, Quaker State, Citgo, and Conoco oils. He found that the 5w-30 oils all had VI's in the range of 158-162; the 5w-20 oils had VIs of 148-154; the 10w-40 oils had VIs of 147 to 150; 10w-30 oils had VIs of 134 to 139; and 20w-50 oils had VIs of 120 to 125.
In 1994, Dr. John Woolum tested the viscosity of several 10w-40 oils in his motorcycle. He found that all of the petroleum oils had lost highly significant amounts of viscosity within 1500 miles. Only Mobil-1 held up in his test. I have personally tested Delvac-1 synthetic in my ST1300. It was 5w-40 when I put it in, and 5w-25 9,200 miles later. By 1500 miles, the petroleum oils Dr. Woolum tested were at 10w-25 equivalent. By contrast, Dr. Woolum tested a petroleum oil in his Honda Accord. After 3600 miles, the 10w-40 oil was 10w-37 equivalent. Motorcycles are indeed significantly harder on their oils than cars. Based on this result and the VI numbers above, it would seem that 10w-40, 5w-20, and 5w-30 oils cannot be safely used in motorcycles for more than 1,000 to 1,500 miles.
You might ask, if these viscosity index improvers are so expensive and fragile, why have them? Why not just run a straight 30 weight oil? If you live somewhere where the temperature never changes, like Maui, maybe that's a good idea. However, if your engine will ever see temperatures below 60 degrees or above 100 degrees, it's important to have a multi-weight oil. Multi-weight oils offer far superior protection during a cold engine start on a cold morning, and they also offer superior protection if your engine oil ever gets above about 230?. Of course, some old timers will tell you, "I always ran straight 50 weight oil. Yup. That was the stuff. All these new-fangled fancy oils, forget it, it's just marketing hype. All you need is straight 50 weight." Well, that may have been true when motorcycles were 1500ccs and made 18hp. Today, when you can casually buy an engine that makes 150hp per liter, things are just a little different.
Viscosity is not actually measured in "weights", but rather in units called "Stokes." If you're a famous scientist they name a unit after you, except for poor Albert who is considered famous enough all by himself. Stokes was a guy who worked on fluid flow. For oils, we use a hundredth of a Stoke, called a centi-Stoke, abbreviated cSt. "Weights" are a classification invented by the American Petroleum Institute (API). A different unit of viscosity, the centi-Poise, is used at very low and very high temperatures. 10 weight oil refers to oils within a range of viscosities, so two different brands of 10 weight oil might actually be quite different. 75 weight gear oil is actually about the same viscosity as 10 weight motor oil. Don't ask me why, I'm not a petroleum engineer; although some might argue that I do belong in an institution.
SAE W viscosity grades for engine oils Grade cranking pumping 0w 3250cP at -30?c 60,000cP at -40?c 5w 3500cP at -25?c 60,000cP at -35?c 10w 3500cP at -20?c 60,000cP at -30?c 15w 3500cP at -15?c 60,000cP at -25?c 20w 4500cP at -10?c 60,000cP at -20?c 25w 6000cP at -5?c 60,000cP at -15?c SAE viscosity grades for engine oils Grade low shear high shear 20 5.6 - 9.3 cSt at 100?c 2.6 cP at 150?c 30 9.3 - 12.5 cSt at 100?c 2.9 cP at 150?c 40a 12.5 - 16.3 cSt at 100?c 2.9 cP at 150?c 40b 12.5 - 16.3 cSt at 100?c 3.7 cP at 150?c 50 16.3 - 21.9 cSt at 100?c 3.7 cP at 150?c 60 21.9 - 26.1 cSt at 100?c 3.7 cP at 150?c a (0w-40, 5w-40, 10w-40 grades) b (15w-40, 20w-40, 25w-40, 40 grades)
The "High Shear" viscosity number is the one that actually correlates with oil film thickness on your bearings at operating temperature. You can see that, based on this, really there's only three choices for oil: 20; 30 or light 40; heavy 40 to 60. The cranking viscosities above show you the temperature at which you can start your engine safely. 20w oils are only safe down to about 28?f. 5W Rotella or Mobil-1 SUV oil are safer at -13?f than 20W is at 28?f.
Motor Oil Additive Packages In addition to the base stock oil, oil manufacturers add what's called an additive package. Additive packages are typically not made up by the oil companies, but rather by a few companies that then sell them. Additive packages contain several different chemicals with several different purposes. Here's what the additive package is supposed to do for you:
One component is detergents and dispersants. These chemicals are designed to hold onto foreign particles and chemicals in your engine, and sometimes break them into smaller pieces. These foreign chemicals may be combustion by products, or junk that slipped past your air filter. If the particles are large enough, then they will eventually be grabbed by the oil filter and taken out of circulation. Another component is buffers. This is typically calcium, magnesium, or boron. These chemicals are present to neutralize any acids which form in your engine. Acids are bad for your bearings and other important thingies. Your additive package will include solvents to break up deposits of tar and wax. In a premium oil, some of the base stock will be Group V diesters to help the solvent package. Where did the tar and wax come from? Remember, when you opened up your $1.09 quart of Spiffo-Magic SuperLube, you got oil, additives, tar, paraffin, wax, asphalt, ash, aromatics (sounds like perfume when they say that, doesn't it?), and the occasional stray bit of cockroach shell. Another component is emergency lubricants. This is typically zinc, phosphorous, and molybdenum. These chemicals are present in case your oil film completely breaks down, due to extreme temperatures or pressures. These chemicals are supposed to be a last resort defense against metal to metal contact in your engine. Oil companies are cutting back on zinc and phosphorous, as these metals are hard on your catalytic converters. They're substituting molybdenum disulfide, which lowers friction and improves gas mileage. It also causes problems for people with wet clutches, that is most motorcycles. The Viscosity Index Improvers are part of the additive package. As we learned above, these chemicals are present to make your oil stay thick at high temperatures. Finally, corrosion inhibitors. These chemicals are supposed to keep your oil from oxidizing or otherwise breaking down due to time or contamination. Yes, it's true, now even your oil has to take antioxidants. API Oil Standards The additive package is made to make the finished oil product meet one of the certifications. There are two classes of certification: S, for Service, and C, for commercial. The certification standards are maintained by the API, the American Petroleum Institute. Over the years, the API has improved and changed these standards. The most current S standards are SL and SM. These standards differ from earlier standards like SH by lowering phosphorus to improve catalytic converter life, and increasing molybdenum to lower internal engine friction and improve gas mileage. Phosphorus was originally added to oils to help protect high pressure areas like cam lobes and crankshaft bearings, so lowering phosphorus levels is a compromise of lower pollution, perhaps at the expense of engine life. Molybdenum is added to improve fuel economy due to the federal CAFE (Corporate Average Fuel Economy) standards, thereby helping GM and Ford keep selling large V8s to the American public, but can perhaps cause problems in engines with wet clutches. Most S additive packages are also designed to be inexpensive so that the resulting oil can be sold at a low price. SL and SM oils are both low phosphorus; SM oils which are labeled "energy conserving" are high molybdenum.
About every three years or so, the API releases a new S standard. The new standard supercedes the old standard, so, for example, the SH standard included extra high temperature deposit protection due to the popularity of turbo engines in the early '90s; SJ oils did not have this high temperature protection, as that portion of the standard was dropped. This means that for some cars, oils made to the older rating systems are sometimes better than oils made to the new standards. SH certified oils are probably the best of the S oils for motorcycles and high- performance sports cars, but you pretty much can't buy them anymore. Oils which are labeled "energy conserving" are bad for any vehicle with a wet clutch, meaning most motorcycles. Essentially all 0w-20, 5w-30, and 10w-30 oils are energy conserving and should not be used in your bike.
Most people blending S type automotive oils are buying their base oils from a company who is most likely using the Chevron Iso- DeWaxing process to make their oils, then buying their additive package from another company that is highly constrained by the API standards. The cost of getting an API certification for a single S motor oil formulation is from $125,000 to $300,000. The cost for C certification is $275,000 to $500,000. Once testing is complete, the oil can be licensed for $825 per year, plus a small royalty fee per gallon sold for all gallons over one million. The length of time between new specifications is now approximately 2 to 3 years, which does not allow a great deal of time to recover testing costs.
Additive companies, such as Lubrizol, Ethyl, Infinium and Oronite develop licensed additive formulas that they offer to oil companies to re-license. It is inexpensive to re-license one of these formulas, and the majority of oil companies choose to do this to avoid the costs associated with testing. Thus, the same chemistry is being sold under many brand names. Because of this, S type automotive oils have pretty much turned into a commodity. Although the people selling a particular brand may wish you to believe their oil is superior to any other, in fact if it's got the API seal on it, it's probably about the same as any other similarly rated automotive oil.
Commercial (Diesel) Oil The additive packages for C (commercial) certification are designed to promote engine life. The additive packages for C rated oils contain extra buffers and detergents to keep the engine clean and free of acids. C rated oils are far better than S oils at holding and dispersing combustion byproducts and other contaminants, and at not becoming acidic. Traditionally these oils are primarily used in diesel motors, which are very expensive and are expected to last a million miles or more. When an engine rebuild costs $10,000 - $15,000 and puts you out of work for a week or three, you don't mind paying a bit more for your oil. The C certification tests have been largely developed by Mack, Caterpillar, Detroit and Cummins to provide the additives necessary to keep these engines running a long time. The latest commercial certification is CI-4 Plus, which includes extra protection for high temperature high revving motors. Since it's designed for diesel motors, they don't care about no stinkin' catalytic thingies, and CAFE is a place where you get a cup of joe and a donut. CI-4 Plus differs from CI-4 with higher detergent requirements and better sheer stability. The shear stability is exactly what motorcycles need due to running the engine oil through the transmission.
Although C standards are changed every few years, the older standards are enhanced, not superceded. So, newer higher rated C oils are simply better than older lower rated oils.
Although few car owners test their oil regularly, most large trucking companies routinely do oil analysis on their diesel trucks. Used oils are checked for viscosity breakdown, for detergent and dispersant function, and for metal contamination that would indicate engine wear. C oils that don't measure up are quickly run off the market place. To prevent engine wear, the best strategy is to keep deposits off the pistons, rings, and bearings. Therefore, diesel oils typically contain half again more detergents, double the dispersants, and a much more expensive and robust VII package than S type oils. If you go to an auto parts store, convenience store, or grocery store, you'll see that there are dozens of brands of automotive oils, all claiming to be the best. If you look at truck stops, you'll see there are only a very few diesel oils sold, typically Rotella, Delo, and Delvac. Trucking companies find what works for them and won't switch. They're not interested in saving a dollar a gallon on some unknown oil.
The C certified oils are all also S certified, just as some S certified oils are also C certified. The best C certified oils are SG, usually SH, sometimes SJ. I don't know of a C certified oil which is SL. The best S certified oils are CF, which is a relatively old and obsolete C standard, and does not include the tests for high speed high temperature engines that CG, CH, and CI have. In fact, CF oil does not meet the current factory standards for Volkswagen or Mercedes diesel passenger cars.
The API charges serious money to test an oil and certify it. If the API really tested the oil in their independent lab, and the oil company pays their royalties on time, the oil company gets to display the API seal on their product. Some smaller companies don't pay the API to test their oils and certify them. In these cases, you won't see the API seal, instead you'll see some words like "Meets or exceeds all manufacturers warranty requirements. API Service SJ, SL, CF." It's up to you to decide if you trust this manufacturer to actually test their oil themselves and tell you the truth about the results.
JASO certified Oil Another institute that certifies oils is called the Japanese Automotive Standards Organization, JASO. One wonders why this Japanese organization has an English name. . . In any case, they have two classifications for motorcycles, "MA" and "MB." MA is the one you want. MB is like the API SL category, it's got all those nasty friction reducing chemicals that may scare your clutch into misbehaving. Again, there is an official JASO seal if the oil has been independently tested. The seal is a rectangle; in the upper quarter of the rectangle will be a serial number, and the lower three quarters will just have the letters MA. If the oil manufacturer did their own testing, instead you'll see just words like "Meets or exceeds JASO MA standards."
Some manufacturers recommend JASO-MA certified oil. AMSOil and Golden Spectro are JASO-MA certified. Some people consider this important. Interestingly, although Honda recommends a JASO-MA oil, Honda oil is not JASO-MA certified. Mostly JASO-MA is pretty much equivalent to SH. In fact, the JASO spec is mostly a reaction to the decrease in zinc-phosphates in SJ and SL oils, and the added molybdenum disulphide in energy conserving oils. Personally, I don't care about JASO standards - they're really not on my radar.
Racing Oil, NASCAR oil, etc. Some manufacturers also sell something they call "racing oil." Normally, this is actually fairly decent oil, but you should not be mislead into thinking racing cars use the best oils for you. Race drivers start their engine one time only, warm it up slowly and carefully, then run the engine near or at the red line for a couple hours. 100 to 500 miles later, they completely tear down the engine and replace all the worn parts, the oil, and the oil filter. If you think you might like to go more than 500 miles between major engine rebuilds, you might consider that your use of your engine is quite different from Michael Andretti's.
Why do we change our oil? We're now in a position to discuss this. Your oil is a combination of one or more base oils and a complicated additive package. The base oils will actually last as long as your motorcycle - many hundreds of thousands of miles, several years. The reason we change our oil is the additive package wears out. The buffers get used up neutralizing acids. The detergents and dispersants get used up clinging to gunk that's too small for your oil filter to pick out. The VII package gets shredded by your transmission. You could imagine a device that pulled out your oil, gave it a very thorough cleaning, replaced the buffers, detergents, and VII molecules, and put it back into your engine. Sort of a motor oil dialysis machine. However, in a country that has Texas and Alaska, in a world where oil is $30 / barrel, this makes no sense. So, we dump out our entire four quarts of oil because 3% of the oil is used up. It's really just a cheap way of getting a bunch of contaminants out of our engine. This is why it does make sense to recycle oil: if you can process the oil hundreds of gallons at a time, you can separate out the base stocks economically. If you use synthetic oils and bring your used oil to a recycling collection point, you can feel especially good: a bunch of school buses and city buses are going to get an extra little kick in their base oil because of you. In fact, you can tell your wife that's why you need this exotic, expensive synthetic oil: it's solely out of your concern for the children. If everybody used Spiffo-Magic SuperLube the recycled oil would be junk, and in no time flat the school buses would all break down and the kids would have to walk to school, 23 miles, in the snow, uphill both ways. Why, in no time flat the kids would lose weight, improve their cardiovascular conditioning, and just generally be more healthy and have more energy. What a nightmare!
Choosing an Oil for Your Motorcycle There are a few special problem areas for motorcycle oil. Most motorcycles have wet clutches, which means the motor oil runs through the clutch. If the motor oil has too much molybdenum in it, there are fears that the clutch can start slipping. No one I know has ever actually had this happen to them, but the warnings are all over your owners' manual and the oil companies' web pages. On the back of all certified oil cans is a circular stamp with the certification. Avoid oils that say "energy conserving" in the bottom half of the donut. These oils contain friction modifier additives that could cause clutch slipping over time. Essentially all 0w-20, 5w-30 and 10w-30 oils are energy conserving, and should not be used in your motorcycle.
Most motorcycles run the engine oil through the transmission, and the transmission gears are very hard on the oil's VII package. This means that over a couple thousand miles, the oil's viscosity can break down. Standard car oils are only good for typically 1500 miles before they've lost about half of their viscosity. Remember, 10w-40 oils contain a lot of VIIs which tend to shear in your transmission, so I believe 10w-40 oils should be avoided. You can't use 10w-30 because of the friction modifiers. This doesn't leave much. Commercial 15w-40 oils are a good choice, because they have relatively few VIIs which are the more expensive shear-stable sort. Synthetics typically don't contain much of a VII package, so shear is not as big an issue with them.
Some people use their motorcycles only sporadically. This means the oil can all drain completely into the sump, leaving no protective film on the bearings. The first start after a long period of non-use can be particularly hard on an engine. Film strength is very important if you're a sporadic rider.
There are several key advantages to using Synthetic Oils:
Synthetic oils have a higher viscosity index than mineral base oils. Synthetics have better resistance to thinning at high temperatures and thickening at low temperatures. Since synthetics have little or no VIIs, synthetics last longer in service without radical changes in viscosity.
Synthetics have a much higher film strength than petroleum oils, so it takes a lot longer for the oil to drain completely off your bearings and into your sump.
Diester synthetics are polar molecules with solvent properties which dissolve residues and combustion byproducts.
Choosing a Break-In Oil for Your Motorcycle The theory that synthetic oils should not be used during break in is the same as the theory that your engine will break in better if you use synthetic oil but add a dinner candle to your four quarts of engine oil. Frankly, I find this theory, um, questionable. Oh, hell, laughable. Corvettes and Porsches come from the factory with Mobil-1 in their engines. Remember, these engineers have designed world-champion engines for F1, Indy, Le Mans 24 hours, etc.
There's a lot of mythology surrounding break-in oil. It's simply not the case that synthetic oils are more "slippery" than conventional oils. Also, break-in of a modern engine is completely different than break-in of an engine made before about 1980. Modern engines, by comparison to something made in the '60s, are pretty much already broken in from the factory due to the fact that today we hold much tighter machining tolerances. The exception, of course, would be the Ural, a motorcycle made on a production line unmodified since about 1935.
I recommend you change your break-in oil at 75 to 100 miles, 100 to 150 kilometers. Your engine does shed a fair amount of metal particles in the first 20-50 miles, and I really can't understand why you would want this stuff floating around your bearings for the first 600 miles, 1000 kilometers.
I put Shell Rotella "synthetic" (87% group III) oil in my DL650 at 75 miles. It burns no oil, gets great gas mileage, and runs great. I recommend you switch to a good synthetic at your first oil change.
Recommendations I get a lot of email, "My buddy has 283,000 miles on his Yamazuki 867 Nintruder, and he's never used anything but 35ó per quart grocery store oil changed every 48,000 miles." Here's the truth: modern Japanese engines are amazingly well engineered and can tolerate a surprising amount of abuse. However, putting automotive oils in your motorcycle and running them for more than 1500 miles is abuse. I abuse my motorcycle enough with the way I ride them without adding on the abuse of using cheap oil that will break down in 1500 miles.
The question of which oil is best is not settled. We know what we want: the oil is inexpensive, lasts a long time, and makes our engine never break. There are various articles in MCN which do a chemical analysis and make recommendations based on the content of the additive package. I am very skeptical of this, as the utility of these chemicals at various levels is never tested, and the base oils are not tested. There are a couple articles that actually test for viscosity breakdown, and standard petroleum oils don't do very well. Consumer Reports once did a 4,500,000 mile test of oils in NYC taxicabs, however these engines only start once per day and are water-cooled, so they mostly avoid cold start-ups and overheating. If you're using a standard automotive petroleum oil in your motorcycle and running it for more than 1,500 miles, you are taking your chances. By 1,500 miles, the VII additives are pretty much all broken down, and the oil has therefore thinned out enormously.
Your engine will not explode if you use Spiffo-Magic Superlube for 4,000 miles. Your engine will not explode if you never use synthetic oils. However, any of these choices puts additional strain on your engine. You buy $65 tires for your car that last 45,000 miles, and $100 tires for your bike that last 8,000 miles. Why on earth would you try to save $5 on each oil change to buy an oil that can't hold up in a motorcycle engine? My DL650 runs its oil through the transmission, I run off-road (extreme environment due to silicon blow-by at the piston rings), I'm pretty much always revving my engine at 5500 rpm or more (red line on the Corvette, the one that comes with Mobil-1 as factory fill). I stress my little engine enough without making it use dinner candles as lubricants. Nor do I wish to make the bearings run in 10w-40 oil that's broken down to 10w-15 oil.
Some people should, in my opinion, clearly use a synthetic oil. You should be using a synthetic if:
you routinely start your engine in temperatures under 40?f, 5?c. you live somewhere where it gets below -35 degrees, and you want to start your car. In this case you must use either Mobil-1 0w-30 or the Canadian 0w-40 Rotella. If you're riding your bike in -40 degrees, I want a picture just before you die. you leave your vehicle sit unused for months at a time. you are unable or unwilling to change your oil within 2000 miles. you have one of these new 4-stroke MX bikes. These MX bikes hold only about one quart of oil, all of them have marginal cooling systems, and if there's a more severe use of an engine than MX, I don't want to be physically present when it happens. If it's below -55c, -65f, stay home. Really.
Three synthetics stand out from the rest: Mobil Delvac 1, Mobil-1 SUV and Shell Rotella T Synthetic. These are C certified industrial oils meant to be purchased in 55 gallon drums and used by companies which run a lot of diesel engines. The Commercial oils, as discussed above, have more expensive additive packages which are meant to prolong engine life and oil life, as opposed to being cheap to buy at Pep Boys and helping the car companies meet their CAFE requirements. These oils meet all the automobile requirements through SJ, and also have extra additives to help pick up gunk in the engine, to keep the oil from becoming acidic, and to maintain the oil's viscosity over a long time. In fact, the manufacturers talk about their oil's viscosity resistance to shear forces - exactly what a motorcycle needs. Shell Rotella-T Synthetic is available at Wal-Mart for $13 / gallon, so I consider this the motor oil of choice. Delvac-1 is very hard to get in the west - there are only two places in all of California where you can buy it. Mobil-1 SUV is readily available everywhere for about $4.50 / quart. When used with the correct filters, these oils are certified for 50,000 mile oil change intervals, and are frequently used for 100,000 to 150,000 miles in diesel long-haul trucks. Now, before you get all excited about the possibilities, you must also keep in mind that the diesel engines don't run their oil through their transmission, and the large diesels all have two oil filters, one a normal paper filter, and the other a 1 or 2 micron filter that catches pretty much everything. We don't have these secondary ultra-fine oil filters on our bikes. Also, the large diesel engines hold eleven gallons of oil - a oil and filter change costs these guys $350 if they use synthetics, $150 if they don't.
The synthetic diesel oils are 5w-40 oils. Some people have expressed concern to me that this doesn't match the 10w-40 specification for their engine. The 5w rating only applies when the oil is cold, below about 80? f. Once your oil and engine are up to operating temperature, these are 40 weight oils, just like all the others. In cold conditions, under 40? f, the 5w oils are much better for your engine than a 10w oil.
AMSOil, Motul 5100, Mobil-1 MX4T, Mobil-1, Redline, and Golden Spectro are apparently made with high quality additive packages, similar to the commercial synthetics. Personally, I would find it reassuring if these oils were CI-4 certified. However, many motorcyclists have used these oils for years with good results. They are all fine oils, and perfectly acceptable to run in your motorcycle. They are a bit on the pricey side. Delvac-1, AMSOil, Redline and Motul synthetics contain no petroleum oils - they're pure synthetic. To the best of my knowledge, all other synthetic oils contain some amount of Group III oil.
Mobil-1 automotive oils all contain small amounts of moly - about 100 to 200 ppm. This can cause clutch slippage in some motorcycles. I've only heard of this being a problem in Honda Shadows.
I'm sometimes asked if it's ok to blend your own oils. Yes, it is. Oils are all made out of pretty much the same chemicals, and nothing really bad will happen. If I wanted to blend my own oil, I expect I would use something like 25% Motul 5100 10W-40 and 75% Chevron Delo 15w-40, which would get me both the advantages of a lot of diester stock (5100 is pure diester) and the diesel additive package. In the winter, however, I would use 25% Motul and 75% Rotella synthetic, to get the superior low temperature performance. In fact, I just run Rotella synthetic in everything I own, year round: ST1300, DL650, Superhawk, Chevy Silverado, motorhome.
I'm also sometimes asked if it's ok to run non-Harley oils in Harley-Davidsons. In my opinion, yes. If you change your engine oil every 3,000 miles or so, you can run pretty much any decent oil. I ran Valvoline in my Harleys for 120,000 miles. For extended oil life or superior protection, I recommend AMSOil, Golden Spectro, Motul 5100 or Mobil-1. Harley recommends a 20w-50 oil, so Rotella or other synthetic diesel oils will not do. However, the 15w-40 diesel oils meet the same film strength standard as 20w-50 oil, and are just fine to run in your Harley. I'm told that the standard Harley oils are made by Sunoco, and the Syn-3 is made by Castrol. The Syn-3 Harley synthetic is primarily a Group III oil, and contains very little PAO or Diester stock. I don't consider the Syn-3 Harley oil either a particularly excellent oil, nor a competitively priced oil.
If you live in another country, you'll have to do a bit of research to decide on an oil. Generally, any oil certified for use in a late model Volkswagon or Mercedes turbo diesel is a good choice. Another good idea is to go to a truck stop and ask the truckers about brands. Rotella is marketed all over the world, but in other countries it's called Rotella or Rimola or Helix Ultra, and the formulation may be a bit different, depending on local climate and preferences. It will likely also be a lot more expensive than it is here. Sorry. I don't make your tax policy. Nor ours. They would all be very different if I did.
If you prefer a less expensive petroleum oil, Chevron Delo 400, Mobil Delvac 1300, and Shell Rotella T are available at any auto parts store for under $7 per gallon, or at Sam's Club or Costco for under $6 per gallon. This price is reasonably competitive with passenger car oils, and you are getting a Group II oil with the superior commercial additive packages. Notice in the table above that these oils have particularly good high shear film strength, meaning the protection you get for your bearings is much better than with a 10w-30 or 10w-40 oil. I don't have any information about how long you can run these oils before their viscosity breaks down, but I'm confident it's at least as long as the best consumer petroleum oil. If you're really into saving money, you can often find these oils locally in 10 gallon drums for about $50. This should keep your bike, your car, and your wife's car in good shape for at least a year. Farmers, ranchers and truckers buy these oils in large quantities, and we get to ride piggy- back on their economies of scale.
A comparison of a few oils. These numbers refer to the blended oils after VIIs are added. Rotella Rotella Syntec GTX Syntec Mobil-1 Valvoline Valvoline Synthetic Synthetic Blend Synthetic Synthetic Rating 5w-40 15w-40 10w-40 10w-40 10w-40 15w-50 10w-40 10w-40 pump Vs 39k ? 60k 60k! 60k! ? ? 30k* Vs @ -30 6400 ? 7000 7000 7000 ? 3150* 6500 Vs @ 40 89 108 89 100 111 125 125 97 Vs @ 100 15 15.5 13 14 16 18 14 14 VI 176 141 148 150 152 153 155 148 Flash 246 213 232 213 213 230 230 216 Pour -40 -24 -33 -30 -30 -45 -40 -33 Ash 1.3% 1.5% ? ? ? 1.3% ? .8% Neutral 10 11.5 ? ? ? ? ? ?
* = @-20c ! = @-25c
[Re: Fred Blackstone]
#811783
05/18/07 03:38 AM
amsoil is actually a really great company, they stand behind they're products 100% and from my experience they are the best out there. the creater of mobile one used to be an employe of amsoil. amsoil was originally used in military planes because they found that it was the only oil that wouldnt get burned up. i know one person thats such a believer in amsoil that he put it in his brand new f150 and only adds one quart once a year when he changes the filter and that is all, he has never yet done a complete oil change and he has over 250,000 miles on it. seeing this is what sold me to it
WHEN THE ROAD ENDS, THE FUN BEGINS
97 sahara, 4in skyjacker lift, 33in tires, borla header & catback, 10in subs
#811784
05/18/07 04:08 AM
The guy made my point zackly when he said: "Thus, the same chemistry is being sold under many brand names. Because of this, S type automotive oils have pretty much turned into a commodity. Although the people selling a particular brand may wish you to believe their oil is superior to any other, in fact if it's got the API seal on it, it's probably about the same as any other similarly rated automotive oil."
That is what I've been saying all along. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: BigJim]
#811785
05/18/07 06:30 AM
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> I thought you'd pick up on just that point if you bothered to read this guy's presentation. Big Jim, this has been fun! You've been repositioning yourself and attacking me throughout this thread. The guy's point is that not all engine oils are the same, but are similar in function if they meet certain standards. Additionally, some oils are better than others for different applications. I won't say that your a self-aggrandizing blowhard, but, again, this has been fun! <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> I hope some readers will find the presentation useful and interesting.
[Re: BigJim]
#811786
05/20/07 04:53 AM
I guess if oil is all the same, then gas is all the same too?? I guess if you change your oil every 3K miles, it doesnt really matter for normal driving. I have used Castrol oil for years (my personal preference, not for arguement sake) and have found that it keeps the engine exceptionally clean. Since I really keep up with changing the oils regularly, any oil would probly have the same result. I watched a demo on oil one day and the rep who handled several lines, cut the oil bottle right above the bottom and let the oil drain away. We all looked at the bottom of the bottle and you would be suprised at the contaminants settling out. The only oils that didnt have this problem were Castrol and Havoline. That reinforced my opinion of Castrol. I burn BP/Amoco fuels (premium when it was affordable) and the combination of these two products have kept me on the road and helped keep my engine's internals clean as a whistle. Just my $.02 <img src="/forums/images/graemlins/notooth.gif" alt="" />
77 fiberglass CJ-7 304, Ground up Resto-mod Edelbrock Air Gap, Holley 1850, Headers and Flowmasters, Black Diamond suspension, BFG 33X9.50 on Outlaw I's. Hopefully on the road this year!
[Re: Mudlover27]
#811787
05/20/07 04:58 AM
Oh and on subject, if your already using synthetic oil, why would you go back to a part dino anyway? Aren't high mileage oils a blend of syntho and Dino? I thought they were meant to put a part syntho oil in to help the older, more worn engines. Am I right about this?
[Re: hlhneast]
#811788
05/21/07 01:07 AM
Ok i been gone long enough now it is time to come back full force <img src="/forums/images/graemlins/lol.gif" alt="" />
Origonal question is high milage oil a gimmick- no here is why. there are additives in it to help soften the gaskets so they reseal,additives to clean out years of carbon and such,and additives to keep carbon from scratching up the cylander walls in the now more worn engine. I know for a fact quaker state adds slick 50 to their high milage engines which i think contains teflon.what other companies use i don't know.
oil is not oil,and fuel isnt fuel. do you really think mobile,Exxon or whatever other companies will sell their high quality oil and fuels to joe schmoes oil company. no they won't they keep it for theirselfs. meaning their oil s and fuels are as good as your getting, the rest has im purities that will still work but not as well. I remember a thread simular to this where i stated the same thing,BJ stated that the days of the exxon tankers with the red stripe and tiger are gone. to which i replied no they are still around and alot. i see them quite often and i will take a picture to prove it <img src="/forums/images/graemlins/lol.gif" alt="" /> At any rate oils have came a long way since even when i was just starting to drive. new additives and so on but none the less the big oil companies will always have the better stuff. personally my wife and i burn exxon gas and i use valvoline oil. we use mobil1 Synthetic in hers since we bought hers new. the way i see it is if gm reccomends mobil1 in the vette,and mercedes does the same it has to be good. i also know that vw and audi and i think saab reccomend castrol. another thing is mercedes will void a warrenty if you do not use synthetic oil when it is reccomended. how they tell i have no idea but i was told that when i ordered a filter from the dealer,he didn't try selling me the oil as well he just said make sure you use synthetic so the warrenty is not voided.
Re: high mileage oil, is it bogus?
[Re: cuervo25]
#811789
05/21/07 01:25 AM
OH i forgot to say anything any company says,or shows their product doing better damn well do it false advertising is illegal. the thing about the additive is yes it may not be a secret but any smart oilcompany will have that mixture of oil and additives copyrighted. for example, mind you i dont know if these are actual amounts or additives but here i go. brand x 10 % teflon 10% detergant 20% conventinal oil 60% sythetic oil. now brand x copyrights that so now noone can legally use the same amounts of those additives thats partially why i think oils are improving. the competition and copyrighting is forcing companies to try different things to keep an edge over their competitors.
[Re: cuervo25]
#811790
05/21/07 10:11 PM
Amisol does make a difference in my TC450 dirt bike. Seems to run cooler or at the very least overheat less frequently. I change it every 100 miles, same with the dual sport. It's only 1 quart and only takes 5 minutes,far faster and cheaper than rebuilding a 4 stroke.
Trucks are a different story. All my 4x4's have gotten cheap 10W40 and a stock filter 4 times a year. Never bothered trying the synthetic for the trucks but guess I might if I ever bought a brand new one. The Toyota 22R and Jeep inline 6 don't seem to have any ill effects running generic oil.
As for the 5000 mile+ oil change I don't get it. You'll still get 5000 miles worth of crap in your oil wether its still the correct viscosity or not. Why would you want to keep dirty oil in your engine for any longer than usual?
If the synthetic oil came out nice and clean at 5K I'd be sold. Until then I still think standard oil every 3months is the ticket for my rigs. One of my friends swears by Mobil 1 in his Jeep,only changes it twice a year. Maybe we'll pull the oil pans one of these days and have a look to see which engine really is cleaner.
[Re: Seattlegti]
#811791
05/23/07 01:49 AM
amsoil is the only company i know of that says you can go 1 year or 10,000 miles before changing it, we go a hole year on it, some of the forklifts at my dads work have had amsoil in them for over two years, and when you pull the dipstick out it is still clean, they are run on propane so they do burn cleaner but normally they were changed once a year with mobile one that came out dirty,last week my brother just pulled the bearings out of one of the semis at my dads work that had over 270,000 miles on it with amsoil since being rebuilt a few years ago, the bearings came out with very little wear, about a month ago he pulled the bearings out of another one with over 300,000 miles on it that used the shell 15w40, the bearings had a good amount of wear.
