Page 2 of 3 1 2 3
Re: SFA rebuild - knuckle removal? [Re: missouriman] #812307 05/17/07 03:41 AM
Dingman Offline OP
Ok, well then, my mind is made up. Tomorrow, off come the Knuckles.
Roger, thanks for mentioning that, I'll take a close look at the bearings, I won't replace the tops if they dont' look worn.
A brass drift it is!
You guys rule!
Paved Roads ~ Another example of wasteful government spending.
'85 $runner, lifted and locked.
See the Ding_yota here
Re: SFA rebuild - knuckle removal? [Re: missouriman] #812308 05/17/07 06:22 AM
OOP'S Offline
here is sort of a write up I did with pictures showing the quick way to tear down a front end. it may help you out some.
I tried to do it that way once on the trail (it is called the "Camo method, he use to change Birfields out in ten minutes). It sucked for me, to heavy and with the arthritis; I have in my hands and elbows it did not work. I do not have to bleed my brakes when I take the calipers because of the way I have it set up. See picture below.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: SFA rebuild - knuckle removal? [Re: OOP'S] #812309 05/19/07 12:37 PM
Dingman Offline OP
Well, I'm slow (my job gets in the way) but I did get one knuckle off and have it pretty well cleaned, I'm going to try to get the bearings changed in it today.
I still need to go find a brass drift tho, tried two diff auto stores yesterday, neither had them for sale.
I have another questions -some signs of damage on one end of the axle, on the bottom of the cup (inside bottom), it looks like the birf or knuckle was rubbing, like the bearing had failed. Shoot, I'll go get a picture and post it - I need coffee first tho, so it'll be an hour or two. I'm just wondering what failed to cause that kind of mark.
Re: SFA rebuild - knuckle removal? [Re: OOP'S] #812310 05/19/07 12:39 PM
Dingman Offline OP
Thanks to all you guys ~ I'm not strong either - baby steps.
EDIT: Doh, I see the same mark on other people pics. Must be from the factory.
Here's a pic - notice the damage that's highlighted. What causes that? What effect will that have on my new bearings and such?
Re: SFA rebuild - knuckle removal? [Re: Dingman] #812311 05/20/07 01:53 PM
Dingman Offline OP
Making Slow progress!
Re: SFA rebuild - knuckle removal? [Re: Dingman] #812312 05/20/07 02:33 PM
Dingman Offline OP
What kind of grease do you guys like to use to put this stuff back together? And do you use the same type of grease in the birfs\knuckle as in the wheel bearing?
I see in the manual it says to use high temp wheel bearing grease when replacing the wheel bearings (which I'm going to do today).
I haven't gotten the high temp grease yet and I was going to put just normal grease in the birfs\knuckle.
I'd like some waterproof grease, maybe I should check at a marine shop?
Any suggestions from you guys?
Re: SFA rebuild - knuckle removal? [Re: Dingman] #812313 05/20/07 03:06 PM
Scerb Offline
I just bought a bigass cup of the red tacky wheel bearing grease from advanced for like 10 bucks and used that through out.
Re: SFA rebuild - knuckle removal? [Re: Scerb] #812314 05/20/07 04:03 PM
Dingman Offline OP
I looked on my shelf I have some tubes of Green grease, so I'll use that but I'll also buy a tub of some high-temp grease, whatever I can find I guess.
Say, do you guys ever replace the rotors at all?
Re: SFA rebuild - knuckle removal? [Re: Dingman] #812315 05/20/07 04:12 PM
Scerb Offline
Rotors are pretty much a PITA without a press. The lug studs are pressed in. You can probably beat them out with a BFH, but will probably need new studs which will need to be pressed in. Real quick with a press though!
Re: SFA rebuild - knuckle removal? [Re: Scerb] #812316 05/20/07 04:34 PM
Dingman Offline OP
Thanks, though I didn't find a thinkness spec on the rotor's, I'm giving them a good wire brushing with the angle grinder before going into the parts washer. I dont have a press, so I'll leave them as is, they don't look horrible. I'll put the new races and bearings in and maybe get to start reassemble today. Maybe not, I'm not going to work on it all day if I can help it.
Have to go find some grease now.... a big, big bucket.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6449 MB (Peak: 0.7504 MB) Data Comp: Off Server Time: 2026-06-07 07:00:19 UTC
