Re: Ball Joint Seperator Tool?
[Re: Mad_Scientist]
#812433
05/17/07 03:11 PM
Hey Scottie. Don't you read the tech section. CV Boot replacementI used the same tool as well. Widen it to 24mm or 1" approximately. Tighten up for decent preload then just tap, or light hit on bottom jaw with hammer.
92 SR, 285/75R16 Yoko MT ARB locker GAST compressor AirLift 1000 MM10500 Snorkel custom rear bumper 02 Montero LS died protecting the master 08 PowerWagon (stock!)
[Re: Alex Kogan]
#812434
05/17/07 04:37 PM
I was trying to show Richard how to get it apart too.. and I wasn't having much luck popping it apart cause I didn't have the fork to preload it. On my accord I used to have I'd just wedge the end of a wrench in there to make some load and then just one good whack and it would pop right apart.. same as doing an idler arm on these trucks.
1999 Mitsu Montero - Crappy Weather 1992 Isuzu Pickup - Zombie Apocalypse 2008 Saturn Sky Redline - Nice Weather
[Re: Alex Kogan]
#812435
05/17/07 04:46 PM
that is the article I was looking for, thanks. I may have missed it when I was looking through tech trying to find it. thanks again!
scottie
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6005 MB (Peak: 0.6544 MB) Data Comp: Off Server Time: 2026-06-23 03:08:37 UTCValid HTML 5 and Valid CSS
