Page 3 of 3 1 2 3
Re: Ball Joint Seperator Tool? [Re: Mad_Scientist] #812433 05/17/07 03:11 PM
Alex Kogan Offline
Hey Scottie. Don't you read the tech section. CV Boot replacement
I used the same tool as well. Widen it to 24mm or 1" approximately. Tighten up for decent preload then just tap, or light hit on bottom jaw with hammer.
08 PowerWagon (stock!)
Re: Ball Joint Seperator Tool? [Re: Alex Kogan] #812434 05/17/07 04:37 PM
87Montero Offline
I was trying to show Richard how to get it apart too.. and I wasn't having much luck popping it apart cause I didn't have the fork to preload it. On my accord I used to have I'd just wedge the end of a wrench in there to make some load
and then just one good whack and it would pop right apart.. same as doing an idler arm on these trucks.
Re: Ball Joint Seperator Tool? [Re: Alex Kogan] #812435 05/17/07 04:46 PM
Scottie2113 Offline OP
that is the article I was looking for, thanks. I may have missed it when I was looking through tech trying to find it. thanks again!
scottie
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6004 MB (Peak: 0.6705 MB) Data Comp: Off Server Time: 2026-06-23 19:53:21 UTC
